How do i get an xy value points chart on the calculator
    Problem Solver:
  • 23 Answers
Go to calculator then on view tab click scientific calculator then you will see the xy you want to use.
Posted on Apr 08, 2008
    Sergeant:
    Champion:
  • 293 Answers
If you know how to use a scientific calculator , just make your calculator a scientific one by clicking the view tab in your normal windows calculator then select scientific, and there you go...
SOURCE:
How do i calculate the ph value of a solution
You can buy ph test strips that change color and you then compare them to a color chart. If you are intending to do a lot of testing you can buy a ph meter.
Mar 07, 2015 | Office Equipment & Supplies
How to simplify this expression xy(a+b)+(c+d)?
If you know the values of a, b, c, and d you can calculate a+b, and c+d. No further simplification is possible.
Aug 28, 2014 | Office Equipment & Supplies
How to find slope with two point coordinates on ti-84 plus calculator
Assuming your two point coordinates are of the form (x1, y1) and (x2, y2).
There are two possible methods:
You can use the slope formula which is commonly known as "rise over run." To do this: slope = (y2 - y1) / (x2 - x1) This means that the vertical distance covered by the two points divided by the horizontal distance covered by the two points is equal to the slope.
You can use your calculator's linear regression capabilities:
First step: Press the STAT button (next to the arrow keys toward the top right of your calculator).
Second: Select the first option, Edit...
Third: Under L1, enter your first x value, press enter, enter your second x value, press enter again.
Fourth: Under L2, enter your first y value, press enter, enter your second y value, press enter again.
Fifth: Press the STAT button again. Press the right arrow button to highlight CALC.
Sixth: Select the fourth option LinReg(ax+b).
Seventh: Press 2ND then 1 (L1 should show up on your screen). Then press the comma button (right above the number 7). Press 2ND then 2 (L2 should show up on your screen). Press ENTER.
Eighth: Once you press ENTER, several values will appear. The a value is the slope of the two coordinates.
Feb 03, 2011 | Texas Instruments TI-84 Plus Silver...
How do we find the coordinates of a maximum,minimum or point of inflexion on the calculator?is it possible to find the differentiation of an equation with the calculator?thanks
Once the graph is drawn you can use the Calculate menu to find
  • 1:value, the value of the function at a point
  • 2:Zero, the coordinate of a point where the function vanishes (has value zero)
  • 3:minimum, the location of a point where the function has a minimum
  • 4:maximum
  • 5:intersect , the value of the function when it crosses the y-axis (y-intercept)
  • 6:dy/dx, the value of the derivative of the function at a point.
  • 7: Integral (f(x),dx)
For most of the foregoing calculations, you need to supply the interval of x-values that is of interest to you.To move the cursor along the curve to set the left limit and right limit of the interval of interest, use the LeftArrow and RightArrow keys.
You cannot find the location of an inflexion point as this requires the knowledge of the 2nd derivative of the function, and this calculator calculates the first derivative only. However, there may be 3rd-party programs that handle this, on ticalc.org website. Use at your own risk and under your sole responsibility.
To access the seven menu options above, you press [2nd][TRACE] to open the (CALC) menu. Use the Down and Up Arrows to move cursor along the menu options.
Oct 28, 2010 | Texas Instruments TI-84 Plus Calculator
Where is the exponent button on this calculator the casio fx 260 calculator?
It is the [xy] key.
I hope this helps.
There is a guide online at this LINK.
If you could, please rate this post.
Mar 22, 2010 | Casio FX-260 Calculator
Exponents
the Xy button, 10 Xy 2 = 100 (10 x 10)
to do a neg exp you have two options, one use brackets if calculator has them.....
10 Xy (-2) = 0.01
or two inverse your number, ie: make 10 into 1/10th, use fraction entry on calculator.
1/10 Xy 2 = 10 Xy (-2) = 0.01
May 31, 2008 | Casio FX-300MS Calculator
Open Questions:
Computers & Internet Logo
197 people viewed this question
Ekse
Alun Cox
