Question about Whirlwind FH-778 Air Conditioner
No cool air coming out of home air conditioner
This is an old '98 Bryant air conditioner. We had this same problem several years ago. Freon was loaded into it several times and several times it diappeared. Finally an HVAC person fixed the problem. It has worked fine for 7 years. The other day the cool air was turned on only to last 5 minutes then hot air blew. Changed the thermostat. Changed the air fliter. Still have the same problem. The fans work inside and out...just no cool air anymore. We have called some HVAC people who are already telling us we are going to have to spend $2-4K for new equipment in the garage as well as the conditoner outside bc it is ALL so old they don't make the parts anymore. I am just afraid that all we need again is freon, but bc we are so nieve, we could be taken for money we can't afford since we are retired and on fixed income.
  • Brian Niten May 31, 2010
    Do you have a local community college with an HVAC program? Maybe you can get in touch with the instructor and they can come out and check it out. Usually free or just parts cost.
    Also if the community college can't come out maybe the instructor can recommend someone. If not maybe you can find someone who does it on the to earn extra money. From what you described it sounds like it needs to be charged again.
    Guru:
  • 587 Answers
Unless your compressor is burnt up, you probably don't need a new unit. If it's a 1998 it's not that old and you can get parts, the only thing is it's probably R-22 refrigerant and they must fix the leak in the unit if that's the problem before adding refrigerant and the refrigerant is expensive.. All they have in a heating and cooling system, that needs replaced, are a few parts. Outdoor unit has a fan motor,compressor, capacitors fan and compressor and a contactor. Furnace has a blower motor, capacitor, gas valve, fan and limit or furnace control board, which they still make replacement parts for.
My advice would be to call some more HVAC companies, till you find one, that is willing to fix your unit and not replace it..
Posted on Jun 01, 2010
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
I have a bryant fin. 15 years old. not getting cool air.i change the fiter.the fan is blowing.
Check the power to the outdoor AC...make sure it is running. If it is, someone will need to check to make sure the compressor is running and that the temperatures & pressures are good.
Jul 22, 2011 | Bryant 463AAC005BA Air Conditioner
Small diameter lines that run to the dryer are iced to twice their diameter. Bryant 3yrs old, after being off , runs nice and cool for 2 or 3 hrs. Only iced up on one end of a connection -- small...
You have a leak and are low on freon...or you have a plugged air filter that is not letting enough air across the coil...
figure out the problem and get it fixed...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 06, 2010 | Bryant 463AAC008BA Air Conditioner
I have a Bryant 661CJ030-E. While in cooling mode
Refrigerants are regulated by the EPA. In order to purchase it, you need an EPA License. If you are low on refrigerant, the leak needs to be found and repaired. This requires special tools.
Additionally, with the information given, it could be an electrical problem. Is the outside fan running, is the compressor running? Your best bet is to call a professional.
Jul 21, 2010 | Bryant 463AAC008BA Air Conditioner
Our Bryant air conditioner that we bought a year ago started leaking water yesterday but was still working. It isn't working at all today even though the thermostat says "on". Is there a way to reset it?
These symptoms usually indicate a problem with the drain. If the drain for the evaporator is restricted it may leak, if it leaks enough it will activate a float switch that turns off the air cooling unit.
The first thing you need to do is locate the evaporator, depending on where you live and what type of home you have it will be in the basement or the attic most likely. There will be a pan under the cooling coils, if in that pan there is water then your drain for the cooling coils is plugged. Look above that pan for another drain line that is the one you need to clean out.
In the pan that has the water you will find some type of float or water switch that is keeping the A/C from coming on.
Send me a message here if you have questions.
May 29, 2010 | Bryant Heating & Cooling
Not cooling
It sounds like it needs freon,you will have to buy a saddle valve to have a service port to do this,and a can of freon,if you know someone who can do this,it needs to be done with gauges,so not to lock the compressor up.
May 26, 2010 | Maytag M7Y10F2A Air Conditioner
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
nope, nope, sounds like a stuck contactor in the electrical compartment of the condenser, but there are actually several things that could cause it.
Sep 30, 2009 | Heating & Cooling
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
298 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
