Question about Vizio L32 32 in. LCD HDTV
There is a burn mark on my tvs power board - Vizio L32 32 in. LCD HDTV
  • Vizio Master
  • 11,800 Answers
In that case the power board is completely fried - it's unfixable, replace it.
Posted on May 31, 2010
Sony kdl55ex500 no power, main board test
Usually, those TVs that have no power issues, have these starting problems:
1) bad power module
2) Burn Capacitor on the power module.
3) check those capacitor first.
Jan 24, 2017 | Sony KDL55EX500 Bravia 55in Lcd Hdtv Ex...
My 42" samsung plasma sparked after a lightning strike near by. I know for a fact the power board is no good. How do I test the other components?
Without any power; how can? Just replace the power board, and then check further. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 06, 2016 | Samsung Televison & Video
Why won't either of two plasma TVs turn on after lightning struck a tree?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 20, 2015 | Samsung Televison & Video
Samsung Plasma TV clicking and not turning on.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to Plasma TVs are given. You can get an idea about the fault to an extent.
Jun 16, 2015 | Samsung Televison & Video
No power light
Power supply regulator board is faulty. Check the fuse first. If found burned out, replace the power supply board. Normally there is no repair to power boards to LCD or Plasma TVs.
Jan 03, 2013 | Televison & Video
Turn on tv and get full screen but after 5 minutes half the screen starts to scramble then goes blank leaving me with half ascreen
I would suspect your power supply deflection board is failing. Normally these tvs have a problem with the hyper board in which the image is scrambled and then clears up. Your problem is just the opposite and indicates a part is heating up on the power board. A good visual look at the board will be your best starting point. Look for burn marks, a capacitor that is rounded on top or leaking. Also look carefully to ensure your CRT bulbs have not leaked fluid onto one of the boards.
It's a starting point.
Feb 24, 2011 | Toshiba 57H81 57" Rear Projection...
I have a Westinghouse 32"
These TVs are notorious for backlight inverter problem. You could look for a complete backlight board(this will be easier if you're not a tech), or you can replace the transformer and transistor(transistor doesn't always go - sometimes you get lucky). The transformer that is bad will have a small burn mark in it where one of the legs comes up from the board. If I was you I would just replace the board since it's easier. I have done about a half dozen of these. Joe
Nov 12, 2010 | Westinghouse Televison & Video
My 50 inch philips plasma tv wont come on. all it does when you turn on the power is that the blue light comes on like usual and you hear a relay click and then a few seconds later you hear a relay clickin...
There are a few common gotchas for all plasma TVs:
Most commonly, a sustain board overheats and burns out; sometimes that prevents the TV from powering and sometimes it does not.
Unfortunately I don't know enough about your particular model to tell in which category it falls.
Second, the power board either breaks too (sometimes as a result of a sustain defection) or filter capacitors on it dry out and prevent the board from powering on properly. This, in turn, is detected by the protection circuits on the power board itself and treated as a short circuit, thus shutting down the board to prevent further damage.
In my experience 80% of the time the problem you describe is caused by burned ZSUS board and 20% are due to defect power board.
As I said earlier when a sustain burns out it sometimes takes down the power as well. Which is to say do not presume that just one board has gone bad.
One of these days I am planning to post a DIY troubleshooting guide for plasma TVs at my site http://www.coppelltvrepair.com .
It's easier than many people think.
For example in your case I'd try to power off the ZSUS board - the one on the right side of the TV when you watch from the back - and turn it on again. If it powers on then the problem is in the ZSUS board.
In fact, there are quite a few such guides circulating around the net.
The problem ,of course, is that it takes time to understand and apply them properly.
Unless you have a lot of time to kill or a desire to enter the field of TV repairs it's usually better to just pay off a good technician.
Developing the qualities to find a good specialist is a challenge well worth the time and will pay many times in life.
The same can not be said very safely for the qualities of repairing plasma TVs :-)
Jan 13, 2010 | Philips 42FD9932 42 in. Plasma Television
AKAI LCT2715 will not turn on gives blinking
This series of TVs has a famous issue with the power board (part number MLT166A or similar). Several capacitors and zener diodes burn out causing some resistors to burn as well. If you are capable of doing component level repairs check capacitors on the board and zeners Z2, Z3, Z4, Z5 and resistors around them. If you prefer to spend hundred bucks and simply buy the working power board for it - ebay is your answer.
Sep 06, 2009 | Akai LCT2715 27 in. LCD Television
Tv doesn't turn on, just bink a red led light seven times
Replace your Tvs convergence board. Go to www.partstore.com, and check for your current TVs model number. Check for its convergence board, and simply install it by carefully removing the old board that looks just like your old one, and replace the cables where the cables for the old ones were. In many TVs, the cables are gray, blue and 3 multicolored sets, which go to connectors marked blue, green and red. The gray and blue go where the gray and blue cables for the old board were. For the multicolored ones, just replace them where the previous ones were placed, marked blue, green and red. All you need is a screwdriver and about 30 to 45 minutes.
Dec 11, 2008 | Televison & Video
Vizio L32 32 in. LCD HDTV Logo
63 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
