Question about RCA D52130 52" Rear Projection Television
Will not come on
Power (LDE) button doesn't like up and will not come on.
    President:
  • 1,099 Answers
The likely problem of this could be blown fuses in the power stage of the Television, if found replace with same rating and if otherwise try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 31, 2010
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Maytag lde 512
see this possibles causes:
Power from the house
reset the c.breaker if are trigger
Heating element
test the heating element see the video
Thermal fuse
test the fuse see the video
Wiring
Test for loose wires, burn or breake, test how to do it.
Jun 09, 2012 | Maytag Dryers
Have a late 2007 macbook pro and it doesn't turn on..tried the pram smc and it still doesn't turn on is there any other way to fix the problem>?
Unplug the power cable; remove the battery then hold down the power button for 30 seconds. Reinstall the battery; plug the power back in and hold down the power button for 30 to 60 seconds and see if it starts.
Aug 01, 2011 | Computers & Internet
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Maytag Dryer Model #LDE 4916 ACE. Dryer won't start
Sorry, no reset button. If it ran a bit without the belt, it may have overheated and blown one of the thermal fuses. You can find schematics and diagrams at
www.appliancepartspros.com
Good luck.
Mar 15, 2010 | Dryers
Generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
Jun 26, 2009 | Coleman Powermate Premium Plus 6250W...
4 wire cord for Maytag lde 410
There is usually a metal strap or a wire from the enter terminal to the dryer cabinet. Remove and discard that. Attach the green (ground) wire the the cabinet. White (neutral) to the center terminal, and red to one of the other terminals and black to the other. (both are "hot" wires)
Feb 06, 2009 | Maytag Dryers
NEED TO REPLACE BELT ON MODEL lde 412 series 02 serial no. 618 889 PX
its a maytag,
LDE 412 series 02, the labelling printing machine at Maytag is notoriously crappy
Unplug dryer
Remove two screws at bottom edge of front panel, under the lip facing up so they are hard to see.
  • May be TORX secure screws(star shap with a pin in the middle), TORX secure bits ~$6 at good tool shops, or cut a slot across the head of the screw and use a flat blade, throw the torx away and replace with phillips head screws, easier for next time
tilt front panel up from the bottom and unhook it from the catches
undo door switch cables
place door aside
lift drum out
motor, belt, bearings, felts, are all easily accessible.
check felts and roller bearings before you put the case back on, often a seized bearing is cause of belts breaking
While you have the case off pull all the lint n **** out of vent and motor area
Aug 25, 2008 | Dryers
I would like to know the year my still working Model LDE 309 electric dryer was made ?
The film card on your machine was update in 1986, looks like mid 70's model
Jul 16, 2008 | Dryers
RCA D52130 52" Rear Projection Television Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
