Question about Microsoft Xbox 360 Console
I put in a disc. it says reading then goes back to open tray. Help me.
    President:
  • 1,099 Answers
The most common reason for the Console saying reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Console including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Console going again!
Hope it works...
Posted on May 31, 2010
Ive a new xbox360 which does the same.. keep trying other disks till it loads then put the disk ur aving problems with and it will load .. mine does it about once every 3 months... andyjack
Posted on Jun 01, 2010
4 Suggested Answers
whootsley
  • 121 Answers
SOURCE: disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Posted on Jan 13, 2008
  • 34 Answers
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Posted on Jun 23, 2009
  • 21 Answers
SOURCE: xbox 360 open tray message; not reading discs
If it won't play any games it might be the laser that reads the disk. I would suggest getting it checked out somewhere.
Posted on Oct 03, 2009
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
My xbox will not read discs it just says open tray
Jun 17, 2010 | Microsoft Xbox 360 Console
I put the disc in and on my tv it says open tray and when I do that and close it it says reading then goes back to open tray.
your drive may be bad if you have a warranty call microsoft they will fix and ship for free. if its a piece of **** when your putting the disc in pound mildly on the top of 360 no promises
Feb 16, 2010 | Microsoft Xbox 360 Console
Hi friend try this:
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive.
Please vote for me.
Feb 09, 2010 | Microsoft Xbox 360 Console
Once you put in a game it gos back to open tray
I'm no expert but it Looks like you got error code E79 it's when your xbox refuse to read the disc well I guess I'll give more detail it's a small circular sensor in the disc tray that allows the games info to the internal hard drive. In your case that little sensor is slight off it's brackets or it is no longer working, try sending it to microsoft if you warranty is still valid . There's also another option " YouTube " type in the adress bar " open disc tray problem fix" ok so I hope this gave you an idea of what's going on. Steph the not so expert guy.
Feb 04, 2010 | Microsoft Xbox 360 Console
Xbox will not read the disc . i put the disc in and it says reading disc then it goes back to saying open tray and does not play the disc.
Problem is simple... disc is unreadable... solution is take the game back from where you bought it, and tell them the problem... they should give you a new copy.
Oct 16, 2009 | Video Game Consoles & Games
READING DISC OPEN TRAY!!!!
I took a small coffee straw and put some liquid silicone in it and stuck it through the front disc tray carefully to the small engine in the back. Hold your finger over the back of the straw so that the liquid stays in until you are over the engine top.Then I put in a disc cleaning disc for about 10 sec and then put in saints row 2 and it hasn't said "open tray" for about two weeks and counting.....
Mar 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 load disc, goes back to 'open tray'...
repairs sound good dude or the disk is scratched!!!!!!!! Clean It !!!!!!!
Oct 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
192 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
