Question about Dryers
GE 5 CYCLE LARGE CAPACITY DRYER HAS LOUD SQUEAL WHILE DRUM TURNING. SOUNDS LIKE metal rubbing
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 31, 2010
How do I stop my GE dryer from squeaking
Check belt look for location of noise and look for items in that area you should locate with process of elimination .
Mar 03, 2016 | GE Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
Jan 05, 2011 | GE Dryers
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Ge Gas Dryer the drum does not turn but motor just hums then kicks out
sounds like motor bearings or drum bearings are froze up and is not turning the belt.
Apr 24, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
