Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Take care
My Whirlpool Duet Sport washer model #WFW8300SW04 has power going to it, but nothing lites or works. what is the problem ?
SOURCE: What does F21 mean on the Kenmore Elite Washer?
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
SOURCE: Kenmore Washer 110.4512600, what does code F21 mean? ( 5d?)
If this is a Kenmore Elite front loader series washer, "F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
SOURCE: Our washer has been displaying the codes F21 and
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
