I have a Sansa e280 MP3 player. When I plug it into the computer the battery charges only for about a minute. than discharges. Is there a replacement battery available? Is so how do I change the battery?
Dave
Below are some things to check for when charging your Sansa player:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
To Remove the Battery...
1. Remove the back on the e200 by removing the 4 screws.
2. Lift off the back by using a finger nail or a small flat head screw driver. It will not take a lot of force to remove.
NOTE: When replacing the e200 battery be sure that the contacts on the battery line up with the contacts on the player.
3. The battery has three gold contacts on one end of the battery, which is near the words SanDisk Sansa. Be sure these contacts match up with the three gold contacts on the back of the player.
4. Lightly push the lined up battery up against the contacts of the player until the bottom end of the battery can be pushed into place.
5. Replace the lid to the back of the player and then plug the player into the computer using the Sansa cable.
6. Once the player has connected to the computer and is ready to be used or says "Connected", unplug the device.
NOTE: If the device goes directly to a black screen after unplugging it, then the battery has been replaced incorrectly. Take the back off the player once again and flip the battery around and the e200 device should work properly.
Testimonial: "All the information was good except would have appreciated information on where a replacement battery could be purchased"
http://www.sandisk.com/sandisk-support/u...
< - check out these distributors see which is closest to you.
Also you can get in touch with us
SanDisk Corporation
601 McCarthy Boulevard
Milpitas, CA 95035
Phone: 408-801-1000
Fax: 408-801-8657
Try pulling the connecting plug out from player port about 2 or 3 milimeters. I had the same problem but when the plug was pulling slightly out it charged. I don't know why this is happening but seems to work.
