Yamaha m70 amp and c70 pre-amp right speaker stopped working
I have a yamaha m70 amp and c70 pre-amp that was working fine now my right speaker will not work on either a or b speaker channel
    Brigadier General:
  • 8,546 Answers
First, lets's determine if it's the amp or the preamp...
Swap the Left and Right channel cables between preamp and the amp with each other.
Did it stay on the right? = amp problem.
Now on the left? Preamp or source.
Plug any Line Level device (CD?) directly into the amp inputs. Work now? Preamp problem.
ALL sources? Preamp - toggle all controls, especially a Tape Monitor to possibly wipe of any built-up oxides in them.
Posted on May 31, 2010
I have 2 qustions?
my guess is that the yamaha has pre-amp outs, most yamaha stuff does, and that is the one you should be using for the main, and hooking up to the onkyo, and letting the yamaha be your zone controler, and the onkyo be your remote amp for your second zone (if your onkyo had pre-amp outs it would work how your trying to do it, but it dont) so exchange there places, and run a pre amp out to any input of your onkyo, and you'll have total volume control of your outside speakers
Jul 28, 2013 | Onkyo Audio Players & Recorders
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
Yamaha RX-V992 AM/FM stopped working & Right Speakers
Go to www.yamahausa.com then support then authorized serice centers. Hope this helps
Jul 06, 2009 | Yamaha RX-V992
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Yamaha 860 st
this could be the pre amp transistor or the power amp , it will need to be tested and other components tested also to make sure they are not causing the pre amp to fail or the power amp to fail
if its the pre amp it will be cheap , if its the power amp then it won't be cheap , other small components are cheap
electech
Oct 31, 2008 | Yamaha Emx88s Powered PA Mixer System
My old yamaha wont stop buzzing
HI SIR .THAT IS NOT BIG PROBLEM.ALL YOU HAVE TO DO MAKE SURE THAT YOUR PRE HAVE THE FLL.1 PROPERLLY EARTHED(THE GROUND FROM YOUR AMP ALSO GOES TO THE PRE )2 ASK YOUR ELECTRONIC MECHENIC TO CHECK IF THER'S NO BROKEN GROUND ON THE BOARD INSIDE.
Aug 17, 2008 | Audio Players & Recorders
Yamaha dsp a2
Check the A or B switches it could be they are turned off!
Sep 28, 2006 | Yamaha DSP-A2 Receiver
544 people viewed this question
 Grubhead
Grubhead
