Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
The "control locked" light is on. I can't start the machine.
I tried unplugging the machine for 5 minutes but that did not help.
    President:
  • 949 Answers
The first thing to try is pressing and holding the "END OF CYCLE SIGNAL" button for 4 seconds. Try that and let me know what happens.
I have listed that you have a GHW9400SU, if you can please verify this from the tag that is just inside the door.
Thanks, I look forward to helping you with this.
Posted on Jun 01, 2010
The locked door light is blinking and it won't open or start can you help me
Try unplugging the machine from the wall for 5 minutes, that may reset the door lock. If this doesn't work you will likely need to call a service technician.
Feb 21, 2017 | Washing Machines
The cancel Light is blinking/won't run.
Unplug the machine for around 5 minutes and then retry, the program in the microcontroller sometimes gets corrupted by electric spikes or frequency from flourescent lights etc.
Jun 16, 2016 | LG Dishwashers
It displays 'control lock' with red light
Here are a few Different models as i do not know yours.
How to Unlock the Control on Whirlpool Duet eHow
Maytag - To unlock the controls, press and hold the CYCLE END SIGNAL for 3 deliberate seconds or until the control lock light goes out. If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, I recommend calling a service technician to diagnose and repair the washer. You could have a failed control console or a bad electronic control board in the washer.
Kemmore- Unplug for 10 minutes.
GE washer - Make sure that the control for the washer is not locked. If it is, press and hold the LOCK button for 3 deliberate seconds (or until the control unlocks).
There is not another way to reset the control board other than completely unplugging the washer as you have been doing. Since the display light up and works, the washer apparently has electrical power supplied to the control board and control console. You could have a failure in the console that is preventing the start button from working. A failed control board or a problem with the door switch could also prevent the washer from starting. Make sure that the washer door is firmly closed.
If the washer will not start after checking the control lock and the door, I recommend calling a service technician to diagnose and repair the washer.
Good luck More info would be helpful. Make and model. Is always a plus.
Oct 02, 2014 | Washing Machines
Control lock stays on
Try holding for 3-5 seconds should unlock controls.
Jan 20, 2014 | Maytag EPIC MFW9600S
Bosch exxcell 7 washing machine (1400) Power cut at home. Display now shows key symbol - 12 minutes 1200 spin speed Have tried unplugging. Controls will not reset
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Jul 08, 2011 | Bosch Washing Machines
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer
look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
Aug 15, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
