Question about Brother XL-3500
How do i set the tension on my brother xl-3010 sewing machine . the bottom thread is always in knots but the top stitch is perfect. i do not know which wheel to turn for the bottom tension.
  • 40 Answers
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
Posted on Jun 01, 2010
Consew machine. My bottom thread has ball knots on the bottom. I have changed the needle and the top stitch is perfect. Please advise.
Re-check the thread that is knotted. It's most likely the top thread causing what is called thread nesting or what I term "thread barfs."
Thread problems appearing on the top of the fabric are generally caused by the bobbin thread. Problems appearing under the fabric are usually a result of upper thread issues.
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the upper tension to the midway point.
http://www.superiorthreads.com/blog/2015/8/what-causes-bird-nests/
Apr 19, 2017 | Consew Sewing Machines
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
How do I fix the stitching on my Brother XL-3010?
Your tension sounds far too loose. Or your needle is blunt.
Jun 25, 2015 | Brother Sewing Machines
My stitch does not sew on right side of fabric. I sew & see the underside of the stitch. I remove the fabric & the stitch is on the underside.... Never known sewing machine to do this. Help!!
Hi. first thing is to remove the threads from the machine, top thread and the bobbin, and replace to manufactures instructions. If still the same the problem sounds as if there is no tension on the bobbin [under] thread, adjust to a light tension. Then adjust top thread tension until the knot is in the middle of the cloth. Most times people keep tightening the top tension..
Aug 10, 2013 | Brother XL-2600I
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
Thread is knoting at the bottom and bursting. The machine is only sewing with elastic thread. When I try sewing with straight stitch or zig zag it will knot at the bottom and burst.
Maybe you need to adjust your tension and double check your threading. I have never (in 50 years) sewed with elastic thread but I think a call to Singer customer service at 1-800-4singer may be in order.
Dec 28, 2010 | Brother XL-3510 Mechanical Sewing Machine
Brother MB 2600
You should not have to adjust the bottom tension when using sewing thread.
There is a tiny screw on the side of the bobbin case - left/loose; right/tight.
Mark the screw head slot and edge of the bobbin case with nail polish or sharpie so you know where you started.
If you are having a stitching problem that appears to be loose bobbin thread, it may be that the machine was threaded with the presser foot down.
Always thread a sewing machine with the presser foot up.
When the presser foot is down when threading, the thread cannot enter the tension control and you get loose, loopy stitching.
Feb 24, 2010 | Brother XL-2600I
Sewing machine Brother xl-5301
When the bottom stitches are loopy it is the top tension which is wrong. I suspect that it is not threaded correctly for it to be this bad. If you have a tension dial make sure that the thread is properly between the disk. Try the top tension on 4-that is an "average" normal setting. Gradually turn it up as needed. A good way to test tension is to use 2 contrasting colours-red and white are good. You will see at a glance where the problem lies and how well you are correcting it with adjustments. You should barely see a trace of the top colour coming through. Rethread the machine top and bottom with 2 colours-set dial to no 4 and go from there.
Jun 13, 2009 | Brother XL-2600
My four-year-old XL3500 seems to have a tension problem. It was sewing fine until after I refilled the bobbin, changed thread twice, and did some zigzag stitching. Now the top stitch is not correct; it...
according to the diagram in the manual, the upper thread tension is set by the wheel/knob on top and just to the right of the thread take up lever and thread guide. If you don't have a manual, go to www.brother-usa.com they have a downloadable manual for your machine.
Jun 04, 2009 | Brother XL-3500
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Brother XL-3500 Logo
1,079 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
