You may have a broken connecting rod. Remove the spark plug and see if you can observe movement in the piston. if you can turn the crank and the piston follows ... it is probably OK. You are saying no compression which would indicate no piston movement due to broken con rod.
I could be wrong ...
Thanks for your interest in FixYa.com
Testimonial: "Thanks, I removed the plug, can only see a valve moving in and out, could not see the piston."
