Question about Craftsman 26 Hp 54" Deck Yard Tractor
No power I was mowing my lawn with no evident problems until I turned on my lights. After a couple of flickers from the lights my mower went dead. At this point, my mower remains dead. I thought it might be the solenoid, but I changed it with no luck. Still no power. My battery is only a few weeks old, so I rulled that out. I'm thinking it might be the starter.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
I think you should check the charging system. You said you replaced the battery a few weeks ago. Even with the charging system not working, the battery might have enough power for a dozen or more start-ups; but using the lights may have drained what power was left. Get or borrow a battery charger and charge your battery. If mower then seems to be working fine, measure the voltage across the battery when the mower engine is running at normal speed (not idling). It should be 13.5 volts or more if the charging system is working. 12 volts or less means it's probably not working. Either test or replace the regulator/rectifier. Please rate me if you think this helped, thanks!
Posted on Jun 02, 2010
Key will not work on ignition.
it has and oil safty switch on it you will have to push it to some flat ground to start it you will have to wait to start it let the oil settle down to level dont leave lawn mower on a hill it will happen every time
Aug 16, 2014 | M T D Products Mtd Gold 50"" 25 Hp Zero...
I have a Lawn Boy silver series self propelled mower, model number 10324-8902967 that leaks fuel from the exhaust under the mower deck after I have finished mowing and turned the engine off. I will drain...
sounds like the needle valve is not seating some have a rubber tip on needle some have it in the seat but the fuel we now have rot the rubber never store with fuel if possible
Apr 02, 2012 | Toro Lawn Boy Self Propelled CARB Walk...
Husqvarna Lawn Tractor LGT 2654 (from Lowes) B&S Intek V-Twin 725cc 26 gross hp 110 hrs. I had a couple of problems with the 2654 in the past but they were electrical. Now the engine seems to...
A common loss of power problem with B&S V twins is a set of crumpled valve push rods. Means you are running on one cylinder which is generally OK unless you also want to mow. Easy to check, pull one plug wire at a time off. If it continues to run on one cylinder but not the other, that is your dead cylinder. As the intake is not opening, there will not be a wet plug. Costs nothing to check and could be your problem.
Sep 21, 2010 | Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Clutch seems to be stuck on toro push mower. The cord will only pull up a couple of inches before it stops.
I had the problem of the cord coming out slightly then stop.
The most likely candidate is you are low on oil and the engine seized up. Make sure you have the proper amount of oil. Remove the spark plug, then take a rubber mallot and gently knock the mower blade (counterclockwise) until it starts turning. Continue this process until you can move the mower blade by hand. Once the mower blade turns freely then the cord will be able to be pulled. I found that these Toros use quite a bit of oil especially if you are cutting a large lawn. Check the oil level before each mow to make sure you are not low.
Sep 11, 2009 | Toro Lawn Mower With Toro Power Tools
Lawnmower won't start up
I have the EXACT same problem with my mower. I called the Black & Decker number listed above, and learned that the mower is under recall for this problem. So call them and find out where the nearest dealer is, and they will fix it for free.
May 27, 2009 | Black & Decker 19" Electric Lawnhog...
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
191 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
