Question about Kenmore Washing Machines
Replaced Kenmore 90 coupler - now NOTHING works!
My Kenmore 90 Series washer had a broken motor coupler. It would agitate, but wouldn't spin. So we replaced the coupler, and now it won't agitate OR spin. Help?
  • Jeniphish Jun 01, 2010
    I'm pretty sure it's not the lid switch...I should have given a better description of the problem (sorry!). The washer fills up, but won't agitate. It will drain, but it won't spin. It sounds like it's trying to agitate and spin...I stuck a screwdriver in the hole where the lid switch thingy is so I could watch it try to spin. I jiggled the basket...I mean - could it not be set in right? My father-in-law changed out the coupler...but he wants me to get some suggestions before he takes it all apart again. Ugh.
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The first and easiest question is: Did you remember to re-connect the Lid Switch???
If it still won't agitate or spin, I'd check that the Motor coupler was installed correctly and hasn't destroyed itself.
I'd also test the switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jun 01, 2010
  • oldguy5 Jun 01, 2010
    Whirlpool / Kenmore top load direct drive washers use a reversing motor.
    Since:
    1. It WILL drain
    and
    2. It Will Not agitate or spin:
    the problem points to an incorrectly installed coupler:
    Hears why:
    The motor has two shafts.
    One of the shafts thru the coupler drives the transmission for agitating and spinning:
    The other shaft is directly connected to the pump.
    Since it will drain (the motor is working) but will neither agitate nor spin (connection thru the motor coupler to the transmission) The first place I'd check is that the coupler has been installed correctly.
    It's easy to incorrectly install the coupler (i've done it myself)
    If it isn't installed correctly,(for example the plastic unit that fits on the gearcase shaft is broken) the motor cannot transmit power to the gearcase.
    That's the first place I'd check.
I have a Kemnore 90 series washer that wont spin the water pumped out, the motor spins but the agitator won't spin. My question would be is it worth fixing?
Hello, Thats sounds like a broken motor coulpler,when its broke it will sound as if its agaitating/spinning yet it doesn't. The coupler is fairly easy to replace and this video will show you to replace it. The part number fot the coupler is 285753A it could be picked up from your local appliance parts store for no more that $20.00 or you could order it online from; assuredparts.com apdepot.com appliancepartspros.com searspartsdirect.com repairclinic.com Gene
Aug 08, 2011 | Kenmore Washing Machines
Kenmore 90 does not spin (sounds like working & coupler is good)
If the coupler is ok then the next thing to check is the brake/ basket drive cam driver, the ear breaks off on em and won't release the brake. You must remove the agitator and drop the tranny to check itffbcc2d.jpg
Nothing is difficult about repairing the washer. I have repair photos HERE
Mar 13, 2010 | Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Kenmore washer Series 90- #110.20924990
Sounds like my problem I just had...motor coupler needed replacing. I fit between motor and transmission and if it is broke motor will turn but agitator will not work as coupler is not turning
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
114 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
