HP Pavilion ZD7360 US generic adapter problems
I have an HP Pavilion ZD7360US notebook, and I want to replace the AC Adapter with an iGo PS0099 AC Power Adapter. Will this damage my computer or the generic adapter?
  • JEB0127 Apr 08, 2008
    Thank you Abrsvcs,
    The rating on the iGo is 130W max, while the HP is 135W
  • JEB0127 Apr 09, 2008
    Thank you,
    The adapter does not allow me to work with my computer, but will charge the battery when the computer is off.
  • 4,234 Answers
As long as the power rating of the power adapter is the same )voltage and amp rating), you will be ok,
Dan
Posted on Apr 08, 2008
  • ABRsvcs Apr 08, 2008
    With the rating on the adapter that close to the laptop, you are ok.
    Dan
  • ABRsvcs Apr 09, 2008
    The adapter will probably drive the computer or charge the battery, but not both at the same time.
    Dan
My hp pavilion dv6448 comes on and cut off without going to windows
it could be dust in and around the cpu [proesser] give ita good clean seen this a lot
Feb 07, 2013 | iTEKIRO Replacement Laptop AC Power...
No power, will not turn on.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/intocircuit-hp-pavilion-dv4-ac-adapter-65w.html
http://www.chargerbuy.com/replacement-hp-pavilion-dv4-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-hp-pavilion-dv4-ac-adapter-18-5v-3-5a.html
Dec 22, 2012 | HP Pavillion NB200UA dv4-1225dx Notebook...
Was working on computer, it shut off. Now it will not power back up. Hp want to charge me to fix problem over the phone
Please try with this steps :
1. Disconnect the AC adapter and remove the battery from the notebook .
2. Press and hold the Power button for 30 seconds.
3. replace the battery and connect the ac adapter
4. turn On the notebook and check
Jun 13, 2010 | HP Pavilion dv8000t Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Power Adapter
http://cgi.ebay.com/AC-Adapter-Power-Supply-for-HP-Pavilion-zd8000-zv6200_W0QQitemZ320256942042QQihZ011QQcategoryZ31511QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jun 01, 2008 | HP Pavilion zd8000 Notebook
Lines on screen of HP Pavilion zd7360us
Hello, please report your story at hpverticalline.com so your computer model may be added to any future legal suits.
Jan 15, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
