After replace print head (original CANON BCI1350Pg) write error INSERT PRINT HEAD,with another print head (also NEW and ORIGINAL CANON) dosen`t print BLACK.Error code E2813?Thanks for your help
SOURCE: Canon Pixma MP150 - Error code E7, light C flashing
Try removing cartridges and manually claening the heads with cleaning solution and cotton bud (q-tip) replace. Print. No luck? Now try uninstalling and reinstalling printer.
SOURCE: error code E2813
This means that your canon printer has had a ink discharge and is covered up and there is ink laying on the sensor, The sensor if it has went out is 20 bucks you can find at a canon parts retailer
SOURCE: i have the canon
Could be that the button for Sheet / Roll has been pressed. This is a popular error caused by the machine expecting a sheet when you are loading a roll. Make sure the light is located on the roll option rather than the sheet.
If this is the problem, you must first remove all media, then lower the covers and lower the media release lever before the printer will allow you to change between roll & sheet.
SOURCE: Error code 03130031-2F13
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
