Question about Garden
We recently cleaned our TimberTech deck with a power washer, not a pressure washer and after we cleaned the deck it ruined the PVC composite planks. The planks are no longer smooth. We've used many cleaners, but nothing worked. The power washer did the best cleaning but the PVC composite planks are damaged. Please advise. Cheryl and Kevin O'Malley
  • ko223 May 31, 2010
    We're looking for another solution. Since we've tried this solution.
    Genius:
  • 1,341 Answers
This is the problem with power wash as I experienced the same thing with a motorbike radiator and unfortunately there is a give and take whenever you use a power wash, sometimes it can even remove paint work and that means it can cause a lot of damage. Any damage would need to be fixed and if the planks are damaged then it may need repolish and paint or varnish re-applied. I hope I have answered your question here.
Posted on Jun 01, 2010
What psi does the gc150 5.0 pressure washer put out? Is it too much for wooden decks and docks?
To answer you exactly I would need to know the model number of the pump. But in general a pressure washer powered by a 5hp engine would put out between 1800 to 2800 psi. The volume (Gallons per minute) would vary from 2.1 to 3 gpm. That being said, any of these variations would allow you to wash a wooden deck with the proper amount of caution. 1st Choose a nozzle with the widest spray pattern (usually the white one) 2nd Hold the nozzle about 6 inches from the deck. 3rd Always used a sweeping motion WITH the grain of the wood. If you find that it's not quite cleaning the way you want you can always move the nozzle closer to the deck or change the nozzle to the next narrower option(usually the green one) Hope this answers your questions.
Apr 28, 2015 | Psi Garden
Composite decking is cracking and peeling off
Hire a reputable contractor
Mar 25, 2014 | Garden
I put bora cleaner and light gloss on it. i think i ruined them. idint realize i should not have done this. how can i get them looking like factory. they are brand new floors
Usually a good cleaning will do. The factory finish is very tough and hard to ruin. ( polyurethane with aluminum oxide).
Usually these gloss manufacturers also make strippers for their finishes. Try using that in a hidden spot and go from there.
Read Instructions & Follow them thoroughly.
Sep 27, 2013 | Somerset Color Collections Plank 5 Solid...
What is best way to clean/repair roof of an aluminum patio room without falling through?
put a coule of planks accross the roof to stand on . spray some chlorine on the roof and leave for 15 mins then get a high pressure gurny and clean each section moving the planks as you go
Jun 13, 2012 | Heating & Cooling
What types of jobs can be done with a troy bilt 675 series 2550 max psi pressure washer
They are handy for any tough cleaning job...
washing cars, decks and house siding are few coommon areas that they are used for...
Once you have one though you will find you are using it for most any cleanup job involving water...
heatman101
May 12, 2011 | Briggs & Stratton Garden
WHAT WILL HAPPEN TO A CRAFTSMAN GAS POWERED 2500 PSI PRESSURE WASHER IF SOMEONE RUNS DIESEL THROUGH IT AS A DETERGENT OR DE-GREASER? WILL THIS RUIN THE SEALS IN THE PUMP? OR CAN THIS PROBLEM BE REVERSED...
If you want to run a very small amount through the engine to help clean carbon deposits I would say that was fine as long as you only used 1-2 ounces to the gallon. But if you want to run diesel through the pump itself I would not recommend this.
I would disassemble pump and thourghly clean all parts being especially careful to clean and polish all vanes on the impeller and bearing surfaces. Inspect and clean seals and replace if needed.Clean and inspect any o-rings and when you reassemble lightly coat all bearing and sealing surfaces with a good grade of silicon grease. Thank you.
Apr 01, 2011 | Garden
Low pressure from powerwasher wand when trigger is squeezed
THIS POWER WASHERS ARE TRICKY, TO OPERATED YOU NEED TO OPEN THE WATER FAUCET CONECTED BY A HOSE TO THE POWER WASHER , OPEN THE TRIGGER AND THEN START THE POWER WASHER, OTHER WISE YOU WILL RUIN THE POWER WASHER PUMP.
Nov 01, 2010 | Briggs & Stratton Garden
My power washer fell off the deck onto side and began smoking. Can I save it
Yes. Replace the air filter which probably got loaded with oil when the spill occurred. Also, remove the spark plug and clean it. Joe
4 thumbs up please.
Oct 10, 2010 | Honda Garden
Used the suction tube with a deck cleaning solution. later I tried to use it with a car wash solution and it would not pull the soap in to wash the car.
Howdy,
vacuum injectors are finicky suckers (pun), and can gum up easily. If you disassemble them, clean the metering pin with steel wool and the ports with a q tip, they sometimes come back to life. Always flush the lines out completely with clean water, especially when using a caustic or concentrated cleaner...
Jan 16, 2010 | Karcher K2.26 Electric Power Washer
I did not use deck for 2 years and no sound now
the answer is in your question lack of use power supply capacitors and transistors if you have left in loft cold low temps ruin hi fi
Dec 17, 2008 | Technics RS-TR373 Single Cassette Deck
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
