Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
How do I replace the drain hose
I need to put on a reducer drain hose to slow the flow of water coming out of my machine as my drain can't handle it and it's backing up. How do I replace the hose.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to release the console and remove the cabinet for access to the pump and hoses.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=001c1ce16dc331c65c09cf692b6d5852
You should see how the hose connects from the pump to the back of the washer, thru the back of the cabinet and to the drain hose.
Posted on Jun 01, 2010
What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
Aug 25, 2017 | Samsung Washing Machines
Occassional leaking of wash machine
The water may be a result of the drain not being able to handle the flow. This can be a result of either the drain hose not being in far enough, a blockage in the drain, or even a slow draining main line in the house. (The above applies if the puddle is from the drain area.)
Mar 31, 2014 | Magic Chef CAV2000 Top Load Washer
Hi the inlet and outlet lights are both on. would appreciate you help. thanks andrea
Hi Andrea - there are two things to check first- empty machine of baskets etc - remove wash arm on the bottom pull upwards - turn handle for the stariner lift the steel mesh - find a plastic contraption with a steel wire running over it - push wire to inside and lift the plastic housing - what you know the drain pump - check there are nothing stuck in the fan like impellar- close door, select drain - switch on - running ok? - assemble.
Secondly there is no water coming into the machine - or very slow - sensors are saying the flow is not good - this will also give the same error.
A bit more tech savvy - off tap - disconnect hose/solenoid - check the filter for dirt etc - if ok put back - make sure you got good H2O pressure. test - if still the same then the flow meter unit is then the problem - Will require someone who knows how to replace this for you.
Jun 16, 2011 | Miele Novotronic W1918A Front Load Washer
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
Is it possible to slow down or reduce the rate at which water drains out of the washing machine? My drain line is restricted and if the load is more than "Small", it drains too quickly and starts...
There is no flow adjustment on the drain on any washing machine, I had a similar problem on my old washing machine, I discovered the problem was the waste water pipe in my house was clogged with scum from detergent residue, I poured liquid plumber where the washing machine drain hose goes into the waste pipe in the house waited for 1/2 hour, then filled the washing machine with hot water, reinserted the drain hose, and wrapped it up with duct tape to prevent further leaks, and the force of hot water uncloged the pipe, .Problem solved
Nov 08, 2010 | GE WHRE5260E Top Load Washer
I have a Maytag "MTW5870TWO" washer that discharges the drain water at a rate faster than a 2" drain line can handle. I have removed and cleaned the drain line trap, snaked out the entire drain line...
I have the exact same problem. My husband has been looking for a reducer.
I read on the internet somewhere today, that maytag washers, have their drain hoses attached too low, and the drain hose needs to be raised above the washer. A cup hook, and a shoe string did the trick. It seemed to help on the medium wash load setting, but started overflowing at the end of the large load setting. My floor is ruined because of this.
What I have read about Maytag washers, I think I will just call it quits with this, and buy a Kenmore.
If someone comes up with a reducer, I would love to know about it.
Jun 10, 2010 | Maytag Washing Machines
Water is always left in the machine when the cycle finishes
Because the water pump operates as a timed cycle, a partially blocked water passage either from the outer drum to the pump, inside the pump, or from the pump to the house drain is restricting the amount of water being pumped. Remove the drain hose from the house drain just enough that you can watch the water flow during a normal pump cycle. The water should be coming out quite forcefully--if just a trickle, then something is blocking the flow. Look for kinked hoses or even a slow running pump.
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaking around machine
ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Jun 04, 2008 | Amana ALW880WH Top Load Washer
Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
76 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
