Question about Sony MegaStorage CDP-CX355 300-Disc CD Changer
Sony cdp cx 355 throws discs inside the unit, not all the time, but now and then, so that I have to reach in by hand to find the disc somewhere on the inside and take it out.
  • 10,594 Answers
Usually it happens when optical lens got dusty in CDP-CX355 cd player as optical block could not read out disc data and spindle motor spins too fast due to error signal thus optical lens gives up and system control moves to next disc and release loaded disc while disc is still spinning fast and resulted throw in turntable that holds all discs.
Put lens cleaning cd in player to clean disc that will most likely solve the issue and if that does not help out, clean lens with good quality cotton swab gently.
Hope these info will help you.
Thanks.
Posted on May 31, 2010
How do you change the turntable belt on a sony megadisc player model number cdp cx 355
Not easily. You basically have to take out the turntable and everything above it. Then you have to make sure the gears are aligned properly as you do it. Not a job for the faint-hearted. I would strongly recommend having a pro do it. There's a guy on eBay, softduds, who does this very well and I would recommend him highly. He really knows these units and can calibrate to factory specs, in the process replacing all the belts.
Jul 30, 2014 | Sony MegaStorage CDP-CX355 300-Disc CD...
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
Sony cdp cx 355 displaying table error
What worked for me was taking the cover off and carefully threading a belt back onto a wheel. There are two motors at the back of the unit, one (I believe) that grabs the discs and moves them in & out of the player, and a second one that rotates the table (i.e., the round slotted thing that holds all the discs). The belt had simply slipped off the wheel that drives the latter. I did remove the back panel as well, to access it better, and inadvertently disconnected a sensor plug, which led to a second round of troubleshooting, but - in the end - I got it working!
Feb 03, 2010 | Sony CDP-CX300 CD Player
Lost my owner''s manual for a sony cdp-cx 355 c.d. player
You can find electrical version in Sony oficial page. for yourn model HERE.
Nov 06, 2009 | Coffee Makers & Espresso Machines
Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Discs falling out
si, al mio que es el mismo modelo le sucede lo mismo... la solución es tirarlo a la mierda o como hice yo solo lo uso de depósito de cd's, ajaja
Dec 12, 2007 | Sony CDP-CX225 CD Player
Sony MegaStorage CDP-CX355 300-Disc CD Changer Logo
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
