Question about Whirlpool Duet GHW9150P Front Load Washer
Error code FH during wash cycle. - Whirlpool Duet GHW9150P Front Load Washer
  • 327 Answers
Hello,If there is water in the unit:
1. Check the drain pump operation
2. Pressure switch hose is in good condition and properly connected to
*Tub and pressure switch
*check there is not a siphon problem
*check wire harness connection to inlet valves,pressure switch,drain pump,flow
*Meter, and central control unit(CCU)
*check all hose for possible leaks
*check pressure switch operation
*check flow meter operation
*check CCU operation
Thanks
Posted on May 31, 2010
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • Apr 29, 2013 | Washing Machines
    It has stopped washing and is flashing FH what is the problem and what should I do ??????
    First try turning off the machine for 30 minutes. Still FH? Next check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
    The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
    One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
    If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
    Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
    Inlet valves can be purchased thru the net and fitted by you easily.
    Mar 06, 2013 | Kenmore Washing Machines
    During cycle receive code h f
    it is a water detection code. there is a very good description and troubleshooting guide here http://appliancehelponline.com/kitchenaid.html. by the way it is fh not hf
    Nov 18, 2011 | KitchenAid Washing Machines
    During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
    If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
    Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
    At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
    If water does not enter the machine suspect the CCU as bad.
    Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
    One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
    If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
    Nov 28, 2010 | Kenmore Washing Machines
    Error code F H keeps being displayed about 8 minutes into a cycle. What do I do? Please help laundry is mounding up!!!!
    flashes if the washer loses power during a running cycle. The washer does not flash FH" when it is first plugged in.
    Press START to continue the cycle from the moment that power was lost
    -OR-
    Press STOP/CANCEL to clear the display and completely cancel the cycle.
    Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    After 27 minutes into wash get an FH error
    The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
    Aug 02, 2009 | Washing Machines
    F H code during cycle, will not complete cycle
    The following link explains the "FH" error code:
    http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
    This is one of the more involved error codes to try to resolve, because it can have various causes. The first thing to try before troubleshooting is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches. If the error code reappears, I suggest you begin with the easy items that you can eliminate first. Double check your fill hoses and water source, followed by verifying your drainage to ensure you don't have a siphoning problem and checking your drain pump for clogs.
    If you still have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
    Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    269 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
