Question about Eureka 1934 Bagged Upright Vacuum
Eureka 1931 bagged upright, I changed the belt but now the cover is rubbing against belt. How do I prevent this?
  • 33 Answers
If your cover is rubbing, you probably put the belt on wrong. It should line up with the belt close to the groove in the underside of unit.
Posted on Aug 31, 2010
I have a Eureka 4800 series the Boss upright with a bag and Hepa filter. I love it! I was just vacuuming with the hose part and all was well and then suddenly the lower brush came on and a "burning" smell...
I had the same problem. Take out the old belt if possible. Remove the 4 screws inside the filter and the 3 on the front of that housing. pull out the foam around the motor. carefully pull out the suction tube that is press fit against the motor. then you can pull the motor out. place it on its side, shaft side up and grab your hammer. tap down the metal sleeve that has been rubbing against the plastic housing. reinstall everything including a new belt and you should be good to go.
Apr 18, 2010 | Eureka 4874 Bagged Upright Vacuum
I have a Eureka Capture and it works fine for 5 minutes then I smell some burning. Is this the belt?
It could be, open up the cover (there are two screws on the top) and then check the belt, and check the brush to see if anything is rubbing on the belt. If the belt seems fine then your problem is somewhere else.
Dec 21, 2009 | Eureka Capture Upright Vacuum Vacuum
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
I have just changed the belt but I continue to get a burning smell on my Eureka 4870 vacuum.
check if you have the correct belt for the machine, that model doesn't use normal belts.. If it isn't and R-belt then you have the wrong belt. It needs to be a that specific belt or it will not work
Aug 28, 2009 | Eureka Smart 4870DT Bagged Upright Vacuum
How do I change the belt?
Turn the vacuum over so the bottom is up.. Remove scews from plate surrounding the brush area..
Pop of the cover plate..
Lift out the side of the brush that the belt connects to..
Put new belt on..
Put the brush back in place.. It might be a bit tough because the new belt will have a bit of tention..
Put plate cover back on and screws..
Jul 28, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
The belts wear and break very quickly as tho something is rubbing against it on one side. It seems to be worse when I use the hose.
Put the belt on the motor in the opposite direction.  When running, the brush should be pushing the dirt to the FRONT of the unit, not towards the rear.
Jul 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Problem getting belt around motor shaft... Eureka The BOSS
make sure the vacuum is in the upright (locked position) - when you lower the handle, this puts tention on the belt. If it is in the upright and locked position, there is plenty of clearance (unless you have the wrong belt.
Apr 07, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing belt
Turn vacuum over, remove looks like 3 or 4 screws, then the top cover will come off, exposing the belt and brush roll. Part 61520 style J belt.
Nov 08, 2007 | Eureka 2271 Bagged Upright Vacuum
Eureka 1934 Bagged Upright Vacuum Logo
96 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
