Question about D-Link DIR-625 (790069292637) Wireless Router
We lost our password and cannot connect to our wireless connection. How can we reset the password. It is a Dlink DIR-625 router
  • Abhishek Saha May 31, 2010
    hardwire laptop to D-Link Router so that you are able to go online.Press Ctrl+R, you will get a Run window.Type "cmd", hit "Ok". Type "ipconfig".Make a note of the Default Gateway.Open I/E and type in the numbers you got of Default gateway.That will take you to the Router Setup. You can reset the Password by clicking ion security Feel free to revert for clarifications
  • 4 Answers
Get a new one
Posted on May 31, 2010
My router suddenly stopped working yesterday and I've tried everything I can think of to fix it. I have one computer wired directly in to it and a few laptops that use wireless connections. The...
Please try to access the router's configuration page by accessing 192.168.0.1 using a computer that is wired on the router.
Default admin user name:Admin
Default admin password:
Please update firmware:
Note:Please do not upgrade the firmware over wireless connection. Anyway you wont be able to do that now but for future reference. Please use the link on the bottom.
DIR-625:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625
DIR-625 rev C:
http://www.dlink.com/products/?tab=3&pid=DIR-625&rev=DIR-625_revC
Jul 10, 2011 | D-Link DIR-625 (790069292637) Wireless...
I am trying to add a password and network name to my wireless router. I have access to the internet, but it's an open connection called DLink. The router is a DIR 625.
To secure your wireless network from unauthorized access, including changing the default SSID from Dlink to something else. Please click in this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Aug 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do you change password
To change the password on the router you'll need to login into it using the userid/password you initially setup, if you don't remember what those are you can always reset the router back to the factory settings via the reset button on the back of the router.
Jun 21, 2010 | D-Link DIR-625 (790069292637) Wireless...
How to reset the security for a Dlink DIR-625 wireless router
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do you retrieve a lost password on dlink dir-625
Is it the password to access the router menu or to connect to is? sometimes the password for the menu is 1-9 or 0123456789 and to connect the default is usually one of the numbers on the sticker on the router itself
Sep 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Need disk and instructions
You don't need a disk to set your router
You can get help here:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Then do this:
Setting wireless network on Win XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Oct 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
DLink DIR 625 Wireless Router
It is the wireless computer setup with the same network name?
Feb 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
196 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
