Question about Garden
Our lawn mower [The Black and Decker Lawn Hog] grass height adjustment level is automatically moving from the highest level setting to the lowest level setting very frequently. Please advise as soon as possible. Email: kevino223@hotmail.com
  • 10,865 Answers
Hello Kevin. Tighten up the entire heightadjustment mechanism so that it is harder to move. It is just too sloppy. J.
Posted on May 31, 2010
How to lower lawn mower
Cindy, if it's already at the lowest setting, you kinda / sorta answered your own question, i.e. it can't be adjusted any lower; but, as you may be aware, there is an adjuster at every wheel, and by putting all wheels at the same - lower - level, you will get a lower, mowing height; and if you've already done that, or there are no 'individual adjusters', they wheels are typically bolted to the frame and there are usually several holes to bolt the wheel to - simply un-bolt and re-bolt to achieve the lowest, preferred height.
Apr 01, 2016 | Garden
How do I engage back the height adjust on my black and decker lawn hog
if there are no adjustments at the rear wheels install new wheels to accommodate mowing hieght
Dec 05, 2014 | Black & Decker Black and Decker Mm575 18"...
How to adjust the height of the mower
If you mower does not have adjusters on the wheels then there should be three holes where the wheels are bolted onto the base. to adjust these you have to take each wheel off and bolt them in the same hole for each wheel. The top holes are the lowest the mower can be set the middle ones bring it up part way and the bottom hole is the highest setting. You should set the mower to cut at least two and a half inches above the ground. The center holes should be good.
May 12, 2014 | Black & Decker 19" Electric Lawnhog...
Black and decker lawn hog 18 was working fine last time used but will not start now what,s the problem
while unplugged rotate the blade a few spins to move the brushes if there stuck make sure the outlet is good and try another power cord
Aug 13, 2012 | Black & Decker Black and Decker Mm575 18"...
My 18" 12 amp B&D mower has become loud and vibrates so much that the wheel height adjustment pops out. Any suggestions?
Most likely bent shaft or blade. Worst case motor is on the way out maybe bad bearing or something along those lines.
Sep 18, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black&Decker MM675 lawn mower height lever would not stay
I would look in my owners manual and get the part number for the height lever and order a new one. You could also try and wire the height lever so it can not move. I am not sure how it engages but you could may be try and bend the lever so it is tight and won't move. Just a couple of ideas.
Good luck
Aug 31, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
Aug 11, 2009 | Black & Decker Black and Decker Mm575 18"...
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
