Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
LED not working
Purchased unit about a week and a half ago, Checked Voltage and Voltage is good, Display will not come on. Unit will not preform at all. What do we do now?
  • 2,841 Answers
Take it back where you bought it or call 1-800-234-6839. It has a 2 year warranty.
Posted on Jun 01, 2010
I have power to the tiller, lights horn etc but when you push the wigwag nothing happens. Motor and brake work when I bypass everything else. Any ideas?
What is the model number of your unit? Here are the most common issues: If motor/gear are operational when bypass, then YOUR MODULAR is defective. Note: if the 1st led light is dimmer then rest, defective modular. You should obtain 24vdc output when throttle is pressed. on output terminals. No voltage? Modular will be contact me....CTM Direct 909-590-1388 x115
Aug 31, 2016 | Health & Beauty
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
OuVery dissapointed and unhappy.
This is a 120volt unit,so I assume it is not the ac unit,try another plug in,in the house,and have the circuit checked that the ac unit was plugged into,there is not enough voltage most likely.
Apr 16, 2012 | Kenmore 8000 BTU Single Room Air...
Display no longer works. Receiver still works, however. What's up?
This is purely a fault in the display unit. you need to check the power supply to the display unit. Check the filament voltage and the grid voltage to the display from the display driver processor.
If absent the power supply should be checked , it can be a open fusible resistor if voltage is absent. If not the IC is defective. Check for dry joints of the display unit, the IC or the connector to the display board.
Oct 03, 2010 | Sony STR-DE197 Receiver
Samsung front load clothes dryer not working.
may have loss to one line of voltage.may only have half the voltage required to power the machine.make sure proper voltage is coming to wiring block at bak of machine.may need voltage meter.
Oct 16, 2009 | Dryers
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
Viewsonic N3260W made loud pop and will not turn on.
We got the part in today and the hubby fixed the tv. It is as good as new. We are very happy with our $62 purchase.
Go to http://store.ramplus.com/fsfspopfrpos.html
FSP228-3F01, FSP Open Frame Power Supply Replacement for Viewsonic N3260W - 32" LCD TV
It worked like a charm and took about 10 minutes to put in new part and put tv back together.
Jan 04, 2009 | ViewSonic NextVision N3260W 32 in....
Help me please
sounds like the main pc board.
Jun 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
208 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
