Question about Dell 1503FP 15" LCD Monitor
Dell 1503FP Mark, I'm assuming the power board is the large board in the centre of the back (where the signal and power connectors are??)
  • 7 more comments
  • Matt Parish Apr 08, 2008
    Do you have an email address i can send it to? Description on the board: REV. No. MP 1.2 (2001.04.13) CODE BN41-00065A MODEL: 1503FP. Matt
    Hi Mark, I've just realised we have a add picture function! I'll send a picture tomorrow. Thanks, Matt.
  • Matt Parish Apr 09, 2008
    Hi Mark, The picture i took last night is too large to add. I will do it again in less quality tonight and re-post. Thanks. matt
    Hi Mark, Here is the picture. Sorry about the delay but i was struggling to get it below 150kb! Hope it helps. Matt
  • Matt Parish Apr 10, 2008
    Hi Mark, I already tried changing the PS but that didn't help. Also removing the inverter board didn't change anything. I used my multimeter on diode setting and i get 655 and 0 the other way round. Matt
    I've worked something out! if i unplug the power plug, leave it 30 seconds, then disconnect the screen data plug from the main board (CN401) then plug the power lead back in, and then re-connect CN401 it works! If i then push the power button (to turn it off) it won't turn back on again. I have to start again. Any ideas why or how to fix??
  • Matt Parish Apr 11, 2008
    Hi Mark, I've read the IC's and here are the results:
    (IC with legs below 1 - 5)
    IC101 Screen un-plugged
    1. 11.82
    2. 4.85
    3. 0
    4. 4.9
    5. 0
    IC101 Screen plugged in
    1. 11.95
    2. 4.85
    3. 0
    4. 4.98
    5. 0
    IC102 screen unplugged
    1. 11.80
    2. 3.13
    3. 0
    4. 3.3
    5. 0
    IC102 screen pluggen in
    1. 11.87
    2. 3.19
    3. 0
    4. 3.3
    5. 0
    I think my trick yesterday was a coincidence. When i plugged it back in today with the screen unplugged, it wouldn't turn on again.
    Hope to hear from you soon.
    Hi Mark,
    I have 12v accross FT127, 101, 100, 121, 102
    3v accross 305, 301, 305, 308
    5v accross 120, 501
    0v accross 126, 127, 252, 105, 115, 107, 304, 302, 203, 125, 408, 407, 406, 404.
    when the screen fires up i get 3v accross 203, 125, 408 and 404 (0v when the screen doesn't come on.)
  • Matt Parish Apr 24, 2008
    Hi Mark, Hope you are ok? I was just wondering how you were doing with the board? Matt
  • 472 Answers
Yes, The largest of the 2 boards in there. (left side of the monitor if you were looking at it from the fornt.)
If you can get a photo of it, it is possible it could be a different variation in your monitor. They tend to slap them together with whatever parts they have.
Posted on Apr 08, 2008
  • 3 more comments
  • Peter Thompson
    Peter Thompson Apr 08, 2008
    Excellent, I will dig out the schematics today if my wife knows where I put them =)
  • Peter Thompson
    Peter Thompson Apr 10, 2008
    Ah ha, you have the older version of the PCB. I have one of those in front of me right now.
    Try another powersupply if you have one spare. It needs to be around 12volts 2amp, or as close as you can get to that.
    The second thing to do is to disconnect the inverter board from the main board and see if you lights return to normal. You will need to use a torch to see if any signal is showing on the screen of course.
    If that gets things running, then we can look at the inverter board.
    The third thing is right next to the power plug there is a large diode there. Use a multimeter and put the probes onto each end and read the result. Then swap the probes around to the opposite ends and do the same thing. The end result of this should be a high number at one reading and then a number around half that for the opposite end.
    These boards have a high death rate. But by the same token have survived way beyond their expected life term. If it has gone terminal, then in this case it's a put it on the shelf and maybe oneday another will come in you can mix and match them for spares.
  • Peter Thompson
    Peter Thompson Apr 11, 2008
    I can't point to a single thing that would cause it but it is power related.
    The reason it's allowing you to turn it on with out the LCD being connected to the board is there is power getting to it to do that. But add the LCD back into the equation and there isn't enough power to boot it all at the same time.
    That make any sense to you?
    Ok, start with this..
    There are 2 large IC's with 5 legs on them (IC101 and IC102)
    If you have a multimeter then put the black lead to anything ground, apply power to the board and check each of the legs on thse IC's (without the LCD panel being attached).
    Write down the results.
    Next, remove the power, connect the LCD and apply power again .
    Check the voltages of those same IC's again and note what they were without the LCD as opposed to now.
    Careful not to touch 2 pins together with the probe.
  • Peter Thompson
    Ok, phase 300 =)
    You will notice all over the place are fuses maked as FTxx, check eash of those with the power on and see if any of those are registering nothing at all with the panel plugged in.
    Just pop the black lead into the metal bracket to use as a ground and you can just romp around then with the positive probe to make life easier.
    It is still possible that although the board is getting the correct voltage, it's not letting out enough milliamps to run everything.
  • Peter Thompson
    Peter Thompson Apr 12, 2008
    Well that is a start. There is something not letting the power accross but only sometimes. I will have a look at this board I have again today and see what voltages should be at the surrounding IC's.
Need new power cord dell 032dvx black 15
Google it "Dell 1503FP Power Supply".
Feb 04, 2014 | Dell Computers & Internet
Does the Dell 1503FP 15" LCD Monitor have VGA
Cable Connections On Back of Dell 1503FP 15" LCD Monitor and Computer connect.gif D-sub(Blue colour) is the VGA cable , hence Dell 1503FP 15" LCD Monitor have VGA capability.
Feb 18, 2011 | Dell 1503FP 15" LCD Monitor
I need a power cord for Dell 1503FP 15" LCD Monitor
any computer store can seel u that or i can sell u one or u can buy one from Amazon, go to the link.
Sep 30, 2010 | Dell 1503FP 15" LCD Monitor
I have trouble turning on my dell 1503fp monitor. The power switch does not work and I'm forced to continually plug and unplug it until it comes on. What is wrong with it?
Sounds to me like there might be some bad capacitors on the power board. When they go bad the have a puffy silver top to them instead of the normal flattop on them.
If you can get inside of that monitor then look for capacitors that look puffy. If you find some then make sure you buy new ones of the same UF rating and at least the same voltage or higher. You will need soldering skills. You would need to unsolder the old ones and put the new ones back on with the striped side facing the striped side on the board.
That should resolve the problem of the power board. If you look at the power board and you don't find any bad capacitors then you'll need to get a new monitor cause the power boards for that monitor is not available.
May 27, 2010 | Dell 1503FP 15" LCD Monitor
Dell 1503FP works, but won't start up again for a few hours
Hello there.
Seems like electronics pack up but try an old one. disconnect all the data cables from your monitor side(HDMI, DisplayPort, VGA, USB etc.) or computer side if the ones on display are built-in. Leave only the power cable. Unplug the monitor`s power cable. Press the POWER button on the front of the display and keep it pressed for 45 secs. Plug everything back and give it a try.
Good luck.
Jan 18, 2018 | Dell 1503FP 15" LCD Monitor
It doesn't pick up signals as good as other R10's
Assuming you already tried a different antenna, check antenna connections inside the case ... the antenna connector's centre conductor should be firmly soldered to the circuit board, and another solder connection from the circuit board to the antenna connector barrel. If the antenna connector has been twisted too much, these solder joints may be cracked and you could try re-melting the solder.
Dec 01, 2009 | Icom IC-R10 Handheld Scanner
Have choice of Dell 15 in 1503FP or Samsung synmaster 15 570v TFT. Which should I choose? Any advice appreciated.THX.
I am angry with dell computers...however their monitors are without equal in my opinion. More settings on the dell monitor. Also i have had dell monitors going on eleven years and have not had one single problem. No I don't work for them LOL:)
Sep 07, 2009 | Dell 1503FP 15" LCD Monitor
The monitor turns off and on repeatedly.
There is a loose connector on the cable or the cable attachment on the PC board. Jiggle the connector as its connected and see if this causes the LCD to fire up.
Sep 01, 2008 | Dell 1503FP 15" LCD Monitor
No picture
Not really its better to go for an LCD screen , its better in colour and power efficiency & space so in the long term it pays itself off
Dec 09, 2007 | Dell 1503FP 15" LCD Monitor
No Picture
Put a flashlight up to it to see if you can see the screen working. The lights for the screen may not be working. Usually the inverter board or bulbs are burned out. You can light up the screen with a flashlight and see the "output" from the pc but it will be very hard to see.especially during the day.
Nov 04, 2006 | Dell 1503FP 15" LCD Monitor
Dell 1503FP 15" LCD Monitor Logo
506 people viewed this question
Alun Cox
