Question about Garden
I have a driveway with trap rock on it. I have having some drainage problems. How can I tell if the driveway was installed properly. I have been reading that certain sized rock should have been put down first and then smaller size rocks and then the top trap rock. If I dig down, can I tell if the guy installed it right? What if he did not install it right. I have a guy who just wants to add trap rock and not deal with the drainage problems. can you help here. thanx
  • pquin1 Jun 09, 2010
    I was asking about a driveway install, there is no user manual involved here. There are basic procedures to follow for driveway installation and I was trying to find out how that is normally done.
  • pquin1 Jun 12, 2010
    yes
    President:
  • 1,561 Answers
You can only tell this if you are able to consult the manual to see if the assemble is in order, because it is possible that the guy might be missing something out and from the user manual you can tell this, atleast it will guide you to see where the fault lies.
Take care.
Posted on Jun 09, 2010
  • Sulaimon Jimoh Olayemi Jun 10, 2010
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Investigate the "delivered cost" of materials for your driveway. Hot
    mix asphalt is usually the cheapest material that can be used. If it meets your
    criteria, there are many advantages. It will last 20-30 years, it's more
    flexible than concrete, is the cheapest of all materials and is less prone to
    damage by debris than any other material. Get several estimates from local
    contractors for each type of material you are considering for your driveway.
    Decide which material will be used for the driveway contruction. Once that
    decision is reached based upon price, availability of materials and the
    identification of a good contractor to actually perform the work, only two
    steps remain prior to your new driveway installation: removal of the existing
    driveway (if one exists) and the design, preparation and layout of the new
    driveway. The design, preparation and layout steps are similar regardless of
    the type driveway installed, with minor changes depending on the material to be
    used.
    Remove the old driveway. This service is usually negotiated for a fee with the
    new driveway contractor, however, it is always best to get several quotes to
    have the job done. Sometimes a hungry contractor will give you a low price with
    the hope of acquiring more work at a later date.
    Grade the new driveway location so that the bare soil is smooth and
    compacted to a depth of nine inches below grade. The new driveway contractor
    will usually perform this as part of the installation price you were given, but
    make sure that is the case. This below-grade layout should mirror what the
    finished driveway will look like with all the curves, bends and straight runs.
    Install six to eight inches of aggregate base on top of the compacted soil in
    the driveway layout. The aggregate base will hold the asphalt (or other
    material), and prevent holes and other weak spots from developing over time in
    the finished surface of the driveway. The aggregate base should also be
    compacted in place before any asphalt (or other material) is laid.
    Install the asphalt (or other) paving. The job is usually done very quickly by
    a good contractor because the "working window" for asphalt is very
    short. Most driveways can be laid in under 30 minutes, but extra time is needed
    to compact the asphalt, smooth it up and clean up. Allow 24 hours to pass.
    Take care.
    Novelist:
  • 145 Answers
Well I did some research on trap rock and it can be large almost like a paver, and maybe that's what you have, or it can also be crushed. I'm not sure which scenario you have. A drive way many times is very solid underneath your stone from being driven on and doesn't retain much water, like in your grass where the soil is soft. Smaller stones can be used and may help you can check your rock layers to see if they were used but the pitch of the land and depth matter most. The water needs to flow somewhere, if it puddles up it will just lay there. With my driveway I could not get that pitch so I put a channel drain in the ground and ran a pipe under my driveway through a trench into a 3 ft pit filled with rock. You can research french drains online. The water will only go as deep as your rocks are and then lay there if the ground is not pitched.
    Can you tell me what a channel drain is. I know what a french drain is. I read online that the driveway installer was supposed to put stone first, then smaller stone and then trap rock. I think that the guy just threw on some trap rock. I do have pitch, I just think that guy did it wrong. Do you know if you have to place rock on the bottom of the driveway or can they just throw trap rock on the driveway alone. Its kind of important, because if they installed it wrong, I will have someone do it right or I can always put some sort of drain in. Seems easier just to do it right than to put in a drain. What do you think?
  • ElectricMan
    ElectricMan Jun 09, 2010
    I can't be positive about the rock layers, but I can tell you that layering the rock makes a lot of sense to me, because the more layers of rock you have the more the water has to seep down through and dissipate. The larger the stones are the faster the water will seep through them. There is a website that I've included that I think will be very helpful
    to you. Its not about the gravel on the driveway, its really about the
    preparation to your driveway that wasn't done. Pitch is the most important thing, water will always seek its own level, so no matter how many layers of rock you have the water will follow that pitch. You can check out a channel drain at the web link listed at the end of this comment. They are used to drain puddled water out into a french drain, as a french drain usually accepts water from a rain gutter pipe not the ground. I needed to use one in my own back yard because I have an old house and the lay of the land pitches back toward my house and the water would puddle up in my back yard.
    http://www.homedepot.com/h_d1/N-5yc1vZ1x...
    http://www.ehow.com/how_4682636_lay-grav...
How deep to dig a french drain side of a driveway
It all depends on the soil conditions, you want to consider the size of your gravel that you use for your french drain and next thing is,
few days before you start to dig your drainage make sure you should contact your local utility company and driveway contractors. Recently, my husband and I just moved into a new house in Long Island area, and I wanted to install a French drain which would help me to hold water. So I got in contact with the local utility company and driveway Long Island contractors to have all the underground utility lines of our property which are located and marked.
Apr 11, 2015 | Plumbing
What would be the minimum pipe size for drainage from floor trap taking flow from shower and from vanity bowl? What is the minimum pipe size for drainage shower? Ditto from vanity bowl?
That depends on the flow rate you want and your local building codes. When I rebuilt my bath, I had poor flow from both the sink and shower. My sink had 1 1/2 inch pipe and my bath had 2 inch. I replaced the entire sink run with 2 inch after the P trap and the shower I used 2 1/2 inch - problem solved!!
Nov 15, 2010 | Plumbing
Our A/C unit is leaking between the inside unit and the heating unit. We've had two repairmen out. Both seemed confident that the lines were clogged and both blew them out. The a/c is still leaking. It...
Could be the pan under the evaporator has holes in it. Did the technicians pull the coil to check for holes in the pan? At the very least, after blowing out the condensate lines they should have poured water into the pan to check for proper drainage and to ensure there were no leaks in the evaporator's drain pan.
It could also be an issue with not having a trap installed in the condensate line. On some sytems that have the condensate line and evaporator coil on the suction side of the fan, no trap installed will allow the water to be sucked back into the pan and eventually may cause the water to spill over the pan. Having the trap installed insures the water will drain properly. It could also be an improperly installed trap that allows air leakage. To give you an example, if the condensate comes off the pan and goes to a tee (used often as a port for blowing or cleaning out the line) and the tee is not capped off when not being used for cleaning purposes, this will allow air to be sucked back through the tee and prevents the water from flowing through the tee and onto the trap.25011e4.png You were correct in not running the unit as water can drip down into a fan motor below the pan and cause it to short out.
One other issue that comes up from time to time is the inability for water (condensate) to drain or trickle down the face of the evaporator coil. This is usually due to dirt blocking the fins of the coil and the condensate accumulates on other portions of the coil and when it hits the blockages of dirt or other debris, it doesn't perform its usual capillary action and follow the fins down into the drain pan, but instead stops, accumulates and then falls straight down into the lower sections. Check the coil's fin surfaces for dirt or other debris. If present, have the coil cleaned.
Sep 03, 2010 | Heating & Cooling
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
I am instaling a shower under my house and i was hoping to get away with not cutting into the concrete for the drainage, is it possible to raise the shower bottom a foot of the ground for the drainage, and...
Yes, you can raise to avoid the cut by raising shower as long as gravity drain can occur, i.e. you can drain the shower to connect to existing drain lines. Definately put the s-trap in, if no trap then plumbing gas comes back and shower will smell. Remember to put in a plumbing vent or tie in to existing vent.
Mar 19, 2010 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
I have a trane unit in the attic that is for the second floor and it is installed on i guess its side has to be that way water is comming out of this hole and into this pan that is connected but the pan...
The water is condensate, which is produced by the air conditioner (this normal), The hole you are refering to shoule be connected to a drain, and should have a "p" trap installed to allow proper drainage and prevent sewer smells from backing up into the air handler. The pan underneath it should be a secondary catch incase there is a problem with the primary drain (the hole from the unit). the secondary catch should also be equipped with either a drain to allow the water to escape, or a moisture sensor to shut-down the air conditioner, and alert the homeowner to the problem, by way of the house getting warmer. The fact that you describe it as simply a hole draining into the secondary pan tells me that this unit is not installed properly. I suggest calling the installing contractor to remedy the situation, before costly ceiling repairs are required.
Sep 25, 2009 | Whirlwind FH-778 Air Conditioner
Condensate drain overflow-not an algae problem.my drain design has a port/stack at the airhandler exit to facilitate anti algae chemicals. I have a vent upstream of the trap discharge. drainage pipe after...
is your return filter clean only last about 3 mo.is the coil plugged (Evap). or the freon is low. and check the condenser make sure it clean too.
Jun 24, 2009 | Heating & Cooling
Waste water problem
you have a blokage in the water drainage
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
