Question about Toshiba Satellite A105 Notebook
"No wireless network found"
"No wireless networks were found." Worked before I removed the case. Does not work after I reassembled. Everything else is OK. Wireless switch is on.
    New Friend:
  • 81 Answers
You may have caused damage, or disconnected the wireless radio when you dissassembled / reassembled the case. Take it apart again and check if the wireless works while it is apart. then identify the location of the radio and see if the connection is damaged.
Posted on May 31, 2010
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Network connection
Make sure your adapter 'Encryption type' and that of the wireless router is the same. Like, WPAK, WPAK-PS2 etc...
Mar 27, 2010 | Computers & Internet
Linksys BEFW11s4 Wireless Router Security Issues
Try changing the router's channel (play around with 1, 6 and 11) and see if it works.
Jun 28, 2009 | Linksys BEFW11S4 802.11b Wireless...
I cant get into the network centre settings and i have no wireless icon
Found this on the web and it worked for me.
"Follow this then restart and everything should come back to normal. It took me 3 minutes and worked fine.
This is to find and delete the networking folder (which is causing the problem):
1. From the regular Aspire One options page, go to the Files panel
2. Click on the triangle to see more icons
3. Click on MyFiles, which opens a file manager window.
4. In the menu bar, select View->Hidden files, to show a tick in the box. You should be in the "My Disk:///" directory.
5. Scroll down until you find folder "gconf" and then click on that
6. Find folder "system" and click on that
7. You should now see folder "networking" listed as one of the folders.
8. DELETE IT! (Right click on the networking folder, and select option delete.)
I just restarted from here and the icon re appeared in bottom right the menu bar, I just clicked on it to set it up with my wifi signal and it did the rest itself."
May 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
Linksys Wireless-G USB Wireless Network Monitor\wlan.ini can't
Start -> Control Panel -> Classic View -> Add/Remove Programs
Find the entry for the Linksys device.
Click "remove".
When it finishes, shutdown/reboot.
Apr 09, 2009 | Gateway Computers & Internet
My light stays red never turns green
This means that it hasnt connected to a wireless router. Make sure your router is wireless, that you have searched for you network and found it. If this still doesnt work then make sure that your routers wireless capabilities are working and try entering the settings in manually to the xbox 360 network settings.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless network found
If it cannot find any networks, check to see if there is a wireless on/off switch on the computer - look carefully some are well hidden. The switch turns the antenna on and off but windows still detects the network adapter and thinks everything is ok.
Sep 07, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Limited connectivity
If the network you are connecting to has wireless security enabled, try to remove all the preferred networks and reconnect fresh and enter your network key.
One possible cause for limited or no connectivity is the incorrect wireless password set on it.
Apr 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cannot connect to my wireless network
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
Oct 20, 2007 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
