You need to call a qualified service to repair your microwave oven, this is not an option.
Standing on your posts seems like you did not perform any similar maintainance operacion on such an appliance before.
The Microwave has a sensor, and a door protective grid preventing electromagnetic waves from being radiated, .
If you do not mount one of the parts correctly you will have high intensity radiations throughtout your place.
Darect exposure to microwave radiation from microwave causes Leucemia, skin cancer, brain tumor, and other DNA related fatal illnesses.
This is not an appliance you can play with. If you mount the door or the sensor wrongly you die.
Get a new oven or find a repair point.
Hello Mapachi,
The switches have no relation with actuating the lever or opening the door. They seem to be just sensors.
Well, I guess the only way to actually find out what the problem is, is
by actually disassembling the door panel and find out what is wrong. It
could be a bit of broken plastic from the lever or the button that is
obstructing the proper working of the button-latch assembly, or even
just a faulty spring. If you think you can handle this, then go ahead
and open it up. You can find the assembly unit diagram in THIS document. In
my opinion, it is always better to get a qualified technician to do
this, especially as microwaves can be dangerous, and if the job is not
done properly, it could prove hazardous.
Anyways, if you decide to open it up yourself, and find out the cause, you can go to THIS excellent website for the parts required, or your local dealer/point of purchase. Hope this helps....
P.S. Before you assign a rating, please make sure that the issue is resolved. If it isn't, please post back as to what you did, and/or any other questions and we will try to assist you further. If you find that the solution I provided you led you or resulted in a resolution, a FixYa! or Helpful rating would be much appreciated :)
Best of Irish luck, CHEERS!
IrishDruid
By the way, THIS document also gives you the part numbers, so if you find a broken part and want to order direct from the manufacturer, it should be easy.
Their phone number is 1-800-422-1230
Cheers!
IrishDruid
Hello Mapachi,
Just wanted to find out how things are going. Were you able to resolve your issue?
Cheers!
IrishDruid
Just checking to see if your issue has been resolved…If it
has, please close this problem ticket with a Helpful or FixYa! rating. I would
be very grateful for your gesture of appreciation.
Should you have any further questions, please feel free to
post them here.
Thank you for using FIXYA!
Cheers!
IrishDruid
Is the button not fully there meaning could a piece be broken off of it that hits the lever to open the door.
Could it be possible for you to take a couple of pictures of the mechanism for me since it would be much easier to maybe see why exactly yours is having this problem while everything looks fine.
Thank you for using Fixya
Hi you can check iam pasting few parts here which might be helpful to you
(Click to enlarge)
Grid is 1 inch square
Item #
3459
Price
$10.65
In Stock?
Yes
Microwave door interlock switches, 2ea. 15 Amp, 125/250 Volt with 3/16" terminals
OR
check the link for your required spare parts
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60AMicrowave
Hello Mapachi
I made a phone call and after a few transfers, got the following information. I'm told this is the only information they (Kitchen Aid) offer for this microwave oven. (I'd ask for a service manual but they said this was all that was available.)
Kitchenaid Customer Service
800-422-1230
HERE is where you can enter the model number of your appliance. It is CaSe SeNsItIvE so enter the model number in all UPPER CASE.
The last digit of your model number is a "zero" and not the letter "O".
Please, go HERE for the manual and parts list for this microwave oven.
Please, let me know if this response was a "FixYa"
or "Helpful" for you or, of course, if you have
any additional questions, etc on this topic.
If the information I provided you w/ resolved your
problem or lead you to a resolution for your
problem or an answer to your question, then, a
"FixYa" rating would be most appreciated. @:)
It is best to wait until the problem has been
resolved b4 scoring the experts who participated in
solving your problem or answering your question.
(Once you enter a rating, the problem will be
closed and we will not be able to continue to assist
you.)
Very often it will take more than one exchange of
information between you and an expert in order to
resolve your problem. If a proposed solution
doesn't work for you, don't rate it yet. Instead,
post back here letting us know and we'll continue to
work w/ you until we find a solution that does work
for you.
Thank you
BJ @:)
That's OK. (regarding the wrong model no.)
Just go HERE instead for the manual and parts list for your microwave oven.
BJ @:)
HI,
Just click HERE all the troubleshooting steps have been listed.Your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Are you sure that given model number is correct?
Is mfg whirlpool?
Select brand >microwave and see availability of parts for your appliance at link below
http://www.repairclinic.com/SmartSearch/...
Links above seem to be helpfull. ...?
See pages 7 , 8
"Latch Board Assembly (Non-Serviceable)"
Also Exploded view of control panel assy at page 3
I copied it right off of the downloaded exploded view of the microwave from the Kitchenaid web page and I see that I gave you the wrong number. Here is the one off of the microwave:
KCMS135GBL0
Sorry for the confusion!
I copied it right off of the downloaded exploded view of the microwave from the Kitchenaid web page and I see that I have given you the wrong number. Here is the correct one from the inside of the microwave:
KCMS135GBL0
KCMS135GBL0
Well, When I press on the door release button, the door will not open. I have the microwave open now and I can open the door by actuating the release lever internally, so what is causing the button to not actuate the release lever? Everything appears to be in their correct places. ????????????
aren't these switches there to be certain that the door is closed before the microwave is turned on??? Or do they actually actuate the latch itself???
