Question about Panasonic PT-50LC13 50" Rear Projection HDTV
I need to replace the lamp in my Panasonic PT-50LC13 tv, but the replacement lamp looks notthing like the original. The original does not appear to be in a housing? How do I replace the lamp TY-LA1000
  • 10,594 Answers
Below image shows original TY-LA1000 lamp that comes in its housing.
Image-1
And this image shows bulb of TY-LA1000 lamp that many sites/ stores offer on less price.
Image-2
Let me know did you received lamp or bulb as replacement to help you out accordingly.
Thanks.
Posted on May 31, 2010
  • bettyb1399 May 31, 2010
    I received the lamp in the housing.
    Looks exactly like the first picture you showed.
    There is not currently a housing in my TV, There is a plastic rectangle and a bulb. We can not figure out how to remove the current bulb.
  • Shahid Electronics
    Shahid Electronics May 31, 2010
    OK, so you got complete lamp.
    Please click Panasonic Support and download insturction manual about how to replace lamp in PT-50LC13 tv. Manual has all details along with exploded views about how to pull out old lamp.
    Here is direct link for same manual copy.
We replace the lamp. How we can program so the signal change lamp will not appear o TV
There is a lamp timer that needs to be reset. In your menu, look for the reset lamp feature in the service or maint. section.
Feb 27, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How do I replace the ballister?
DLP TVs use Ballast board it is what turns Lamp on! Take back off look for capacitors 1000uf16v if any of these are puffed up on top they are bad.Ballast board plugs in easy to replace,for good working board look up on ebay got one for 57.00 Good Luck with the repair.
Sep 16, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
167 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
