Question about GE AGQ10AJ Wall/Window Air Conditioner
Through the wall AC doen"t work just a humming sound.
Model abn24dar1 won't start just a hum when turned on? the ac was made in 3/97. Serial #fs110246
  • 1462 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Posted on Mar 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore 1995 Built in Microwave humming sound only when door is close
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www.searspartsdirect.com
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 23, 2008
IrishDruid
  • 2712 Answers
SOURCE: Dryer model DBXR463. Power is
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
  • 17 Answers
SOURCE: compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Posted on Feb 10, 2009
  • 20 Answers
SOURCE: hear water dripping when i run the ac
your condensation line is blocked
Posted on Aug 07, 2009
The AC makes a humming sound when starting the fan. If I spin it by hand it runs. Model 620315.321 serial 90716722.
The humming sound is the motor trying to start, if you turn it by hand, usually they will run. it sounds like the motor for fan needs cleaning and oiling. God-Bless ya all!
May 20, 2016 | Dometic Rooftop RV Air Conditioner
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Air conditioner hum often
Is your AC unit a wall mounted unit or a cassette ? And do you know if it has a pump fitted or if its gravity fed drain system
Jul 08, 2012 | Goodman Heating & Cooling
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
Printer won't turn on and AC Power Adapter plug is making a humming noise.
hi
if the AC adapter is humming, refrain (stop) from using it !
the adapter is physically damaged and the internal transformer has been dropped several times to make such a noise.
you will have to purchase a new AC adapter, p/n should be and it should cost about $10-$15
ADP-25FB
pleae issue 4 thumbs up ... thanks for using FIXYA
May 10, 2011 | Lexmark X5150 All-In-One InkJet Printer
I have humming noise from earphones connection Minidisc MZ -N1
Are you using an AC adapter, or running it on batteries? If 'wall-wort' AC adapter, that's the issue. If you're running it on batteries, sounds like a bad ground, try different earphone/headphones and see if the hum goes away. With the 2nd pair of headphones/earphones, does the hum go away, or if you wiggle the headphone jack back and forth a little bit?
May 02, 2010 | Sony MDS-JE320 Mini Disc Player
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Hum in sound
the tv is picking up a 60 cycle hum from the bond wire.they did not filter the main audio board.to fix it buy a 3 wire to 2 wire ac plug without the bond wire. plug it into the wall socket an it should fix the hum. it fixed mine an now no hum. fletchb321.
Jul 24, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Emerson quiet cool
a real hummer. humm can be the sound of a short.but it sounds since u did only turn the fan on it hummed ...fanns are blower motors in acs the motor I bet ate it and needs a new one no way of fixing the motor but most are easy and cheap to replace...go or call an ac applance man ...see if he got a good used one for you or go the manufacture take model make serial no. sometimes u can spin the fan while on and it takes off again...this is dangerous so use a plastic long something but will dy again after u turn it off. good luck. CrazyLarry
Jun 30, 2007 | Emerson Quiet Kool 10MW42K Air Conditioner
GE AGQ10AJ Wall/Window Air Conditioner Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
