Question about Motorola Computers & Internet
Can i connect my motorola dch3416 dvr to my laptop and save programs that i recorded to my hard drive?
  • 493 Answers
Motorola DCH3416 has an USB port to connect to a PC. But you can't copy the files from DVR to laptop, they are encrypted and locked down, even if you opened the box and pulled out the drive you wouldn't be able to get a PC to recognize the format or copy the files off the drive.
(You can not connect data devices without contacting your service provider.
Because the Digital Rights Management (DRM) laws instituted by the entertainment industry prohibit the movement of copyrighted content from one system to another.)
Hope this helps
Posted on May 31, 2010
How can I delete unneeded data from the hard drive of a 'first alert' camera/DVR system?
bring up unwanted program then edit should let you save or delete there .
Jul 18, 2014 | First Alert Home Security
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Nov 28, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
Connect headphones to dvr model 3416
you would need a "doggle" to switch from stereo (the red and white near the yellow on the back) to headphone. i have seen the sort of thing at best buy and radio shack.
good luck
Aug 31, 2011 | Motorola Mobility DCH3416 (160 GB) DTV...
Would like to know how to download prog recorded on DCH3416 onto a usb hard disk connected to my computer for storage
can't... FCC says your not aloud because you may break copyright laws.
that usb port on the dvr only has power... no data. you can use it to charge your phone or power a little fan... thats about it.
sorry
Feb 09, 2011 | Motorola Televison & Video
S0900?
Poor signal. Check connections at all Coaxial connectors. Should be tightened. Unplug a/c from rear of DVR for 30 seconds. Allow time for DVR to reboot and update. Try again. If not resolved, call tech support for your cable company. May have to boost your signal.
Jul 29, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
I received an error 4 code on my comcast supplied motorola dch3416 hd dvr, looking up this error on the web it was suggested that i reset the device, but did not specify how. can you help?
Hi chestmcn. Here's how you reset your device to its defaults:
1. Make sure your receiver is plugged in, that it's connected to your TV, and that your TV is turned on.
2. Turn your receiver OFF, then press MENU on the front panel of the box. You will then see a menu on your TV.
3. Using either the up/down buttons on your remote control or the up/down buttons on the front of your receiver to navigate. Use the right arrow button to view the options for each setting.
4. Arrow down to the setting labeled "Restore All Defaults", then press the right arrow button to select that option.
5. Exit the menu and save your changes by pressing the POWER or MENU button.
For what it's worth, this issue may also be related to Comcast reference code error s0900, which means a disruption in service, usually temporary.
In case you run into more trouble with your receiver, here is a link to the user guide- http://www.motorola.com/staticfiles/Business/Products/TV%20Video%20Distribution/Set-tops/QAM%20Set-tops/All%20Digital%20QAM%20Set-tops/DCH3416/_Documents/Static%20Files/DCH3416_User_Guide_537529-001-c.pdf
I hope this helps. Thanks for using FixYa!
Mar 24, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
I want to hook up an external hard drive to increase the record time available for my Motorola DCH3416 cable box. I already have drives with eSata, USB, and firwire ports.
From the Motorola FAQs:
How do I transfer my programs from my Motorola DVR to an external device like a computer or hard drive? trnsp.gif Question How do I transfer my programs from my Motorola DVR to an external device like my computer or hard drive?
trnsp.gif Answer No. Currently you can't offload recorded content to any external device from a Motorola DVR, even though the data ports are there, the software doesn't support it yet. When the option becomes available through a software upgrade, it will be downloaded to DVR automatically by service providers/cable companies.
Jul 09, 2009 | Televison & Video
How to connect a motorola DCH3416 to a computer Can I connect an external Hard drive to a DCH3416 USB or SATA port so that programs record to the externl HDD, or how can I tranfer recorded program to the...
Nope...
The eSATA ports are not configured in the device's firmware, and the USB 2.0 ports are useless except for charging your iPod or powering a USB fan. If you could connect an external drive to the unit, it would be partitioned with data encryption that can only be accessed by the particular DVR that formatted the drive. You can however stream local channels to a video capture card via the firewire ports but cable channels and DVR recorded programs would be encrypted. You can thank the MPAA for the grief...
Jun 24, 2008 | Televison & Video
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Computers & Internet Logo
1,370 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
