Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
The height adjustment lever is automatically moving from the highest setting to the lowest setting on its own very frequently. We started using our new lawn mower for only a month. Please advise as to what we should do. We're looking forward to hearing from you soon. Thanks, Cheryl and Kevin O'Malley.
  • ko223 May 31, 2010
    Yes it was very helpful. We're going to try it.
  • 10,865 Answers
Hi Cheryl and Kevin. Your lever needs to be bent so that it is more firmly in position. J.
Posted on May 31, 2010
How to raise the deck of a Toro SS 5000 mower above the highest factroy setting
Hi Robert:
I'd start by looking at the mechanism with the engine off while someone else moved the height adjust lever from hi to lo several times.
There will be 2 or 3 linkages that connect the deck vertically to the height adjust mechanism. Shortening these linkages should raise the cut height. If you're lucky, there should be enough clearance to allow the linkages to be drilled so that you can simply move the mounting pins into the new holes.
Or, you could make shorter linkages.
Best of luck.
Sep 30, 2015 | Toro TimeCutter SS5000 50 in. 22HP Smart...
My blade adjustment lever is stuck in the highest position
Hi Cindy:
Blade height is achieved by raising or lowering the deck so it sounds like you really only may have one problem.
If the height adjustment lever is stuck and will not move, it should be fairly straightforward to look at the various components to see where it is binding, and then make corrections as necessary.
Safety First. Have the engine OFF and the key removed before you start exploring the bits.
Cheerfuls.
Sep 24, 2015 | Garden
I have a Honda HRX217 versamower and I would like to know where the wheels should be for the highest height for my lawn, or should I buy a riding lawn mower to get more height. My lawn is dying with
Move the 4 wheel adjustment levers to the number 4 position which is all the way forward (towards you if facing the front of the mower) and that is the highest setting which is about 4" cut height. Each number for the lever position represents the inches in cut. In between numbers is 1/2" so in between 2 and 3 would be 2 1/2" cut as an example.
Aug 22, 2012 | Garden
Fix deck height adjustment on a Snapper Comet 308X.
reset the chains to raise it up
Apr 19, 2012 | Garden
How do I access the servo motor?
I have the same/similar problem. I disassembled the vacuum and discovered that it was not actually the servo motor itself. The problem on mine was little a little sensor.
The motor that raises and lower the height adjustment obviously need to stop when it reaches the highest setting (or the lowest setting) so that it doesn't over-adjust itself outside of the normal range (example an elevator in a building must stop trying to go down when it reaches the lowest floor, and must stop trying to go up when it reaches the highest floor.) In the vacuum there is a little slider and a pair of sensors that 'tells' the vacuum when it hits the bottom or top height. The sensor in mine had gotten mashed up and was not working anymore. Unfortunately the position it was in when it got mashed was all the way up, and worse, because it had been triggered to tell the vacuum that it had reached its highest point, it disable the adjustment motor from making further adjustments.
So I bought a new sensor part ($15) (US) but since Electrolux didn't actually stock them, it took almost three months to arrive. Unfortunately for me, I have since forgotten where all the little pieces and parts came from. I am trying to find a repair manual to help me reassemble it properly, and I'll remain cautiously optimistic about this.
Hope this helps you with some insight in your problems possible diagnosis and resolution.
Jan 24, 2012 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Even on the highest setting, it still cuts too low. can i adjust it to cut higher?
When you put it in the highest setting can you see the deck actually moving in an upward direction? If not the linkage might be broken or damaged. When you raise the deck up or down with the lever it should move, a deck setting in the full up position is a pretty high setting you have to have some long grass to be cutting in the full up position and still think its to short. You might be able to reposition the deck, if when you look under the unit you see a bracket that controls the deck height setting that has a number of holes in it(maybe even 2 brackets), there should be a pin(s) in one of the holes this could be set in a low position and therefore you can change position to change height of deck.
Oct 15, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Bissell powertrak is stuck in the high position, knob moves/changes but the height stays on high
Hello. The height of the wheels Will stay in the highest position until you release the handle release lever. At that time the adjustment will happen. I hope this helps. let me know.
Aug 06, 2009 | Vacuums
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
77 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
