Question about Ruud UBHC Air Conditioner
Whats the best way to repair a 10gage solid wire that got cut?
  • 6,927 Answers
Put it together with a wire nut
Posted on May 31, 2010
851ford powermaster tractor wiring diagram,for 12v..3wire alt...4 post solid..
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 27, 2016 | Cars & Trucks
All the wires in TS0524LB-86E is cut off from inside the sensor. how to solder the wires. it is having red, white, blue and green wires
Depends on where they were cut. How much wire you have to work with on both cut ends will determine how to best repair them.
Aug 16, 2014 | Cars & Trucks
My turn signal fuse blew out I replaced it turn signals worked until I turned my truck over the fuse blew again I have a 1989 ford bronco II what is the problem and where do I start to trouble shoot?
Hello! The Purple/Orange wire that runs from the fuse (#8) to the Turn signal flasher before it passes through the flasher and goes to the multi function switch Is grounded; either resistively or solid...If you have a multimeter and a wee bit of experience using it set it on the X10 ohm scale...Turn key off...Pull the fuse that blows...I believe #8...Read from the fuse side that connects to the Purple/Orange wire to ground...If you read to ground; Pull the flasher out and read again...If the ground remains with the flasher out the wire is grounded somewhere along the harness...If the ground goes away when you pull the flasher then the flasher is defective (not my first choice)...The best way to repair is to run a new wire from the fuse to the flasher and cut the Purple/Orange out...
Take this a step at a time and let me know what you find...Guru.............Saailer
Aug 28, 2011 | Ford Bronco II Cars & Trucks
I was wondering what is the best way to wire a CB radio on a Class C, RV. I currently plug it nto the cigeratee lighter, but the radio picks up the noise of the engine. Any suggestions?
Your best bet is to hard wire it and provide a solid paint free ground so that engine noise is better eliminated. Im not sure what you have for wires, if it only has a cigarette lighter connection then there will only be 2 wires under the cig lighter insulation.. Obviously they may be black and no way to identify which one is power and which one is ground, you are going to have to trace the wire once its cut and see which one is leading towards the mini fuse inside the plug and which one is wired to the ground clip, obviously the one with the ground clip or the one connected to the spring prongs which put pressure on the cigarette plug is the ground wire and the other gopes to ignition power with an inline fuse to protect your CB radio. Wire that wire to an ignition switch source and the other to a solid ground connection.Try it out and see what happens, let me know how u made out.
Good luck.
Lex..
Jun 20, 2010 | Car Audio & Video
The lights are on in amp and it goes on but cuts out and fuses are still good
Check your ground wire to the amp. Make sure at the least you are using a 4 guage wire. Whenever i install a system I never hook to an existing ground. Best thing to do is drill a hole, sand down to ensure a good solid connection and screw that ****** down
May 21, 2010 | Car Audio & Video
Need to rewire Lakewood Fan
wires should be color coded. You can go to the hardware store and pick up some crimp connectors
Jul 07, 2009 | Lakewood 007 Floor / Box Fan
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tuner replacement on RCA D52W20
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken coaxial
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Nov 10, 2008 | Samsung LNT4066F 40 in. LCD Television
Ruud UBHC Air Conditioner Logo
29 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
