Question about Garden
21 hp twin cylinder engine,whats the wires comming out of the carburator bowl hook to? i put this engine on another chassis and engine has to run on choke or it dies
    Problem Solver:
  • 11 Answers
The wire that comes from the bowl is a electric fuel shutoff it needs to be connected to ignition switch and have no power to it when the switch is in the off position
Posted on May 31, 2010
Can I swap the motor from a Husqvarna YTH 180 and put it in a Husqvarna YTH 1848 HP?
The 1848 uses an 18 HP Twin cylinder engine. Mine is a Kawasaki but a similar 18 - 21 HP Kholer will also work. Can't see a problem
Nov 06, 2014 | Husqvarna Garden
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Gas ran out of sparkplug hole
If you had raw gas in the cylinder to where it poured out of the plug hole you most likely have a carburator problem. Inside the carburator is a float and needle, the float pushes the needle into a seat when the bowl is full of gas so no more gas will flow into the bowl or the engine. If the float won't float or the needle is damaged or has dirt between it and the seat the gas will continue to flow into the carburator and on into the engine. If enough gas gets into the cylinder the starter won't be able to turn the motor over. You should also check your oil, usually when gas gets into the cylinder it runs into the crankcase and thins the oil to where it will damage the motor if run for any length of time.
May 09, 2012 | Briggs & Stratton Briggs Stratton Intek V...
18 hp v twin will not run. It is gettng fuel to carb but will not run. It will run when you spray starter fuel in carb but does not continue to run.
There is a solonoid valve in the carburator that shuts off fuel to meet emissions standards. Be sure it is wired to be powered when key is in run position. You can hear a "click" at the carb. when the solonoid powers up.
Jan 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp briggs will run for a little while then die. Checked coil and new gas
It's possible that you have condensation built up in your carburator. Tiny droplets can deny gas to the cylinders. Since you put in new gas and I assume you are getting spark, drop the bowl on the carburator and check for this culprit. Could be a quick fix.
Hope this helps... Good luck!
Oct 04, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Carburator problem,18 H.P Vangard V-Twin(350777-1113-E1)
it sounds like the needle valve is stuck open. This is connected to the float, and when the bowl gets low the float pulls this needle out of its seat and allows fuel to run in. Sometimes tapping on the bowl can resolve this. The needle is usually made of brass and can become corroded from water or from sitting or wintering over. if you take the bowl off you could also clean this up if tapping a little does not resolve the issue.
Apr 13, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
