Question about Intel Motherboard
When i connect the power supply to the mother board it does not come on.
  • TechXcell
    TechXcell May 31, 2010
    Excuse me! That's just plain rude! Chuck it out the window right now! *ROFL* Just kidding... (in case u r shocked).. you've given me nothing to work with here! Model Number? New or Old? Is there an on-board LED on the Mobo? Power supply working? Did you connect the power button jack? Is the board inside or outside the cabinet? You see... How much you made me wonder!
    President:
  • 995 Answers
Hi!
Replug the system power connector from the motherboad and then reseat also your memory and processor.
Make sure that you properly plug all the connectors.
Please leave comments for further assistance.
Thank you for reaching us.
Posted on Jun 01, 2010
4 Suggested Answers
SOURCE: motherboard
I have had 2 of these MotherBoards do the samething. I had to replace them. it seems they only last about a year or 2.
Posted on Sep 19, 2007
Benimur
  • 6966 Answers
SOURCE: trying to put a mother board together need help
Hi LadyT18,
Apparently your power supply is an ATX 20-pin type (v1.x) and is the standard a year or 2 back. Your motherboard being fairly recent uses the new standard which is ATX1 24-pin type (v2.x).
Your options are:
1. Replace your power supply with a higher wattage/XX pin;
2. You may still use the old 20-pin power supply provided that it is rated 300 watts or higher. Additionally, please bear in mind that using a 20-pin PSU to an ATX1 (24pin) may cause boot failure and/or instability during operation due to insufficient power delivery.
I scanned part of a motherboard's manual to illustrate how this could be done. Below is the image for your reference.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 13, 2007
map9966
  • 2351 Answers
SOURCE: Mother Board connection
Go to the site below. Its a manual for the 800/i65GV group. Go to page 67 and zoom in. You'll get a nice look where everything goes. Two rows of pins. Upper row and bottom row. Real close to each other. Do not place connectors up to down. Connect only left to right.
The reset connector has two pins. One will be white or black. These are - grounds. So connect it to the bottom row onto the most right two pins. Moving to your left. Skip one pin. Take the Power Switch a two pin connector. Remember Black & White is ground & ground goes to your right for both rows of Mb pins.
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4p800/e1324_p4p800.pdf
Go to IDE_LED next. Its the last two pins towards your most left of the bottom row of pins. Move to the upper row & the power LED. Same as the bottom row keping the grounds to your right. Lastly is the speaker. Its connector holds four pins but you only use two. One in each end.
Good luck & please vote....
Posted on Dec 22, 2007
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
The fuse in my BR 300 ATX power supply has blown, what is its replacement part
You need to replace the fuse and dis connect the power supply to the mother board and turn nit back on and if the fuse blowns again then it is the power supply, that is bad, bou if it blowns only when connected to the mother board, the mother has a bad component on it.
Sep 16, 2011 | Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Power supply pulled from working system about 1.5 years ago. Connected to the previous mother board. On board power LED solid green. Tried to power up, but the light just flickered very fast. Tried...
try 800W power supply? also make sure you connect the big flat multi cable plug and small 4 cable plug into the mother board usually on opposite side of the big plug
Mar 02, 2011 | ASUS A-55GA (A55GAATX550WAPFC) 550-Watt...
My s88m g/gl motherboard is not switching on ,but the power supply is working
Power supply is other thing, means she ( Power Supply ) supply the power to *********** board. When mother get the power than she supply all the device. If, *********** board have problem, means not connect properly or burn ( any device ) than she not run. Better you check your all connect device with processor also.
Aug 12, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
