Question about Garden
I have two complete Pontec watercourse kits: reservoir, pump, hose, fittings and pebbled 6' sheet that acts as the bed. I have no installation or operation instructions Does any one instructions for this kit? Will the pump included (marathon 400) pump up an 18' path with an 8' rise?
  • 713 Answers
Hi,the instruction manual of your device can be downloaded for free at www.manualsonline.com or www.manualnguide.com,probably you can get it at their website.in addition,the marathon 400 will definitely pump up an 18' path with a 8' rise
Thanks and take care
Posted on May 31, 2010
  • lextrex May 31, 2010
    Thanks for your quick response.
    Neither manual site has any pontec manuals. The manufacturer has no manuals posted on their website. I sent an e-mail to them requesting the manual.
    I am building a small downhill stream. Do I need to put underlayment under the lining material or can I go just with the plastic liner. There will be some large boulders along the path laid on the liner (app 150-200 lbs.). Do these need underlayment under them to protect the liner?
  • Oyelade Gbenga May 31, 2010
    the set-up needs an underlayment which will serve as a protector to the liner,but its not so necessary,however,since you have sent an e-mail requesting for the manual,i will suggest you excise some patience,because the manual will be sent to you,it's only a matter of time
    Good luck
How involved is it to replace a power steering pump on a 2007 Explorer 4.0?
Power Steering Pump - 4.0L Special Tool(s) Installer Set, Teflon® Seal
211-D027 (D90P-3517-A) or equivalent Material Item Specification MERCON® V Automatic Transmission Fluid
XT-5-QM (or XT-5-QMC) (US); CXT-5-LM12 (Canada) MERCON® V
Item Part Number Description 1 388898 Teflon® seal 2 - Pressure line-to-pump fitting (part of 3A719) 3 W700839 Power steering pump bolts (3 required) 4 3A674 Power steering pump 5 W503924 Pressure line bracket-to-engine bolt 6 3691 Power steering pump supply hose 7 W503924 Power steering pump supply hose bracket bolt
Removal
NOTICE: While repairing the power steering system, care should be taken to prevent the entry of foreign material or failure of the power steering components may result.
  1. Using a suitable suction device, remove the power steering fluid from the reservoir.
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
  1. Remove the power steering pump pulley. For additional information, refer to Power Steering Pump Pulley - 4.0Lin this section.
  1. Remove the pressure line bracket-to-engine bolt.
  1. Remove the power steering pump supply hose bracket bolt.
  1. Release the power steering pump supply hose clamp and disconnect the hose.
  1. Disconnect the pressure line-to-pump fitting.
    • Remove and discard the Teflon® seal.
  1. Remove the 3 bolts and the power steering pump.
Installation
  1. NOTE:A new Teflon® seal must be installed.Using the Teflon® Seal Installer Set, install a new Teflon® seal to the pressure line fitting.
  1. Position the power steering pump and install the 3 bolts.
    • Tighten to 25 Nm (18 lb-ft).
  1. Connect the pressure line-to-pump fitting.
    • Tighten to 75 Nm (55 lb-ft).
  1. Connect the power steering pump supply hose.
  1. Install the power steering pump supply hose bracket bolt.
    • Tighten to 11 Nm (97 lb-in).
  1. Install the pressure line bracket-to-engine bolt.
  1. Install the power steering pump pulley. For additional information, refer to Power Steering Pump Pulley - 4.0Lin this section.
  1. Fill the power steering system. For additional information, refer to Section 211-00.
Apr 13, 2016 | Ford Cars & Trucks
Bleeding hydraulic clutches
Did you replace the master or slave cylinder?
If you replaced the clutch master cylinder, make sure you bench bleed it before you install it. Bench bleed it by getting a "bleed kit" (plastic fittings that screw into the hole where the hydraulic line connects to it, and a couple of hoses) secure the master cylinder in a vise (don't crush it, just hold it firmly), insert the plastic fitting and attach a hose. Fill the reservoir with brake fluid, then route the hose back into the fluid within the reservoir. insert a rod into the end of the master cylinder where the brake rod goes, then slowly push in and out until you don't see any more bubbles.
Then remove the plastic fitting and quickly install. Make sure to keep some rags handy to put under the master cylinder as it will leak a little while you're trying to get it installed. Keep in mind that brake fluid can ruin your paint, so wipe any off immediately.
If you replaced the slave cylinder and it's not bleeding, you can connect a long vacuum line to the bleeder valve on the slave cylinder and hold it in the master cylinder fluid reservoir. have someone pump the clutch slowly until all of the bubbles are gone, then bleed it the "old-school" way, by opening and closing the bleed valve while someone pumps for you.
Hope this helps
Jul 23, 2014 | 2006 Mercedes-Benz Vito 112
How to change powerstering pump chevy uplander
I just finished replacing mine.
It is much easier if you do these steps:
1. Remove the serpentine belt.
2. Remove the nuts holding the main fuse box over the battery.
3. Remove the reinforcing bar over the battery.
4. Remove the battery.
5. Remove the windsheild washer tank.
6. Now you have access to remove the pump pulley. Without removing the stuff, it may be possible, but it will be extremely difficult.
7. Remove the pump pulley.
8. Loosen the high pressure hose fitting.
9. Remove the return line clamp.
10. Remove the power steering pump mounting bolts.
11. Remove the high pressure hose fitting.
12. Remove the power steering pump while sliding off the low pressure hose.
13. Remove the clips holding the reservoir on the pump.
14. Remove the reservoir.
15. Install new o-ring on the reservoir.
16. Install reservoir on new pump.
17. Install clips to hold reservoir on pump.
18. Install new o-ring on high pressure fitting.
19. Place new pump in position while sliding on low pressure hose.
20. Loosely attache high pressure fitting.
21. Tighten pump to mounts.
22. Tighten high pressure fitting.
23. Install clamp on low pressure hose.
24. Install power steering pulley.
25. Install washer reservoir.
26. Install battery.
27. Install reinforcing cross member.
28. Install fuse panel.
29. Install serpentine belt.
30. Bleed the power steering system.
Dec 13, 2012 | 2008 Chevrolet Uplander
Can you buy sheets for sofa beds easily?
You can just use regular fitted sheets on a sofa bed although sometimes they don't fit very well or get torn. There are places that sell sheets specifically for sofa beds, such as; http://www.bedlinensetc.com/sofa-bed-sheets.html
Sep 10, 2012 | Furniture
Replace power steering pump on 06 chevy uplander
Jul 08, 2012 | 2006 Chevrolet Uplander
My 2005 Avensis sedan front windscreen washer does not work - wipers do still opperate. Where is the fuse for this located and what else could cause this problem?
PROBABLE CAUSE Impact to the front bumper pushes the bumper back far enough to break the washer pump hose fitting. CORRECTIVE ACTION Replace the windshield washer reservoir and washer motor with updated parts. REPAIR PROCEDURE 1. Turn the ignition switch to ACC (I) to unlock the steering column. 2. Raise the vehicle on a lift. 3. Remove the right front inner fender. Unhook and pull back the bumper for better access. CLIPS (6 places.) SCREWS (6 places.) RIGHT FRONT INNER FENDER 4. Release the hooks on the upper right side of the front bumper. 5. Remove the clip from the filler neck, then remove the filler neck. FILLER NECK CLIP WINDSHIELD WASHER RESERVOIR CLIP WASHER MOTOR CONNECTOR BOLT BOLTS WASHER TUBES 6. Remove the right front fender trim, and disconnect the washer hose from the 90-degree fitting. CLIP FRONT FENDER TRIM FRONT HOSE 7. Disconnect the 2P connector and the two washer tubes from the washer motor. 8. Remove the washer reservoir clip and the three bolts, then pull out the reservoir. 9. Assemble the new reservoir components, but do not install the filler neck. 10. Trim 85 mm off the end of the 1,260 mm washer tube only. 11. Route the washer tubes on the reservoir. NOTE: The black fitting is for the front windshield nozzles, and the white fitting is for the rear nozzle. 85 mm 12. Install the reservoir. 13. Connect the rear tube to the straight fitting in the wheelwell. 14. Connect the 2P connector to the washer motor. NEW RESERVOIR Connect the rear washer tube. CLIP BOLT 9.8 N•m (7.2 lb•ft) 15. Install the filler neck with the original clip. Connect the front washer tube to the 90-degree fitting. Then reinstall the front fender trim. WASHER FLUID DIPSTICK 2P CONNECTOR FRONT FENDER TRIM FILLER NECK CLIP
May 15, 2011 | Toyota Passenger Cars & Trucks
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
How do I fix my window washer pump on my 2000 dodge caravan?
One can get a repair kit that includes a new motor pump and wiring clips, or
one can get the original motor that plugs into the windshield wiper fluid reservoir.
Windshield wiper reservoir (gives idea of how to change the windshield wiper fluid pump motor) Removal & Installation To Remove:
  1. Disconnect and isolate the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the right front wheel and splash shield.
  4. Disconnect the electrical connectors from the pumps and detach the rear washer hose.
  5. Place a drain pan under the reservoir if it contains fluid.
  6. Disconnect the front washer hose at the wiper unit in the engine compartment. NOTE: The front hose will be removed with the reservoir.
  7. Let the fluid drain from the reservoir.
  8. Remove the mounting screws and the reservoir.
To Install:
  1. Install the fluid reservoir with the mounting screws.
  2. Connect the front washer hose in the engine compartment.
  3. Connect the electrical connectors and rear washer hose.
  4. Install the splash shield.
  5. Install the right front wheel.
  6. Lower the vehicle.
Aug 27, 2010 | 2000 Dodge Caravan
HOW DO YOU TAKE OFF A POWER STEERING LINE? I HAVE A 96 FORD E150 5.8
When power steering hose replacement is required, follow these steps:
  1. With the engine stopped, remove the return hose at the power steering gear, and allow the fluid to drain from this hose into a drain pan. On some cars, the vehicle must be lifted on a hoist to replace the power steering hoses.
  2. Loosen and remove all hose fittings from the pump and steering gear.
  3. Remove all hose-to-chassis clips.
  4. Remove the hoses from the chassis, and cap the pump and steering fittings.
  5. If O-rings are used on the hose ends, install new O-rings. TRW steering gear cylinder lines have gaskets that are serviced as a unit. The old gasket must be pried out of the fittings in the housing before the new lines and gaskets are installed. Lubricate O-rings with power steering fluid.
  6. Reverse steps 1 through 4 to install the power steering hoses. Tighten all fittings to the manufacturer's specified torque. Be sure all hose-to-chassis clips are in place. Do not position hoses where they rub on other components.
  7. Fill the pump reservoir to the full mark with the manufacturer's recommended fluid. Bleed air from the power steering system. Check the fluid level in the reservoir and add fluid as required.
Jul 07, 2009 | 1996 Ford Econoline
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Jan 04, 2009 | 1989 Ford Mustang
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
