Question about Kenmore 63942 Dryer
Not getting any heat at all - Kenmore 63942 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 31, 2010
WHAT DOES IT MEAN WHEN HEAT IS SET 66 AUX IS FLASHING
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
Hi,My remote do not get the good temp in my house. Ex: I set to 80F in heat mode but the thermopump operate slowly and dosn't get hire than 70-72F. The remote see the unit and all. Is the sensor in th
You have a heat pump.
Once the outdoor temperature falls below 36 degrees, heat pumps will sharply lose their ability to heat.
If you are getting a 72 degree indoor temperature when the outdoor temperature is 28-30 degrees, the heat pump is performing up to spec.
On heat pumps, the air coming out of the nearest air vent to the unit should be heated approximately 40 degrees warmer than the air entering the unit.
If you have a 70 degree indoor air temperature, the heat pump should be supplying 110 degree air at the closest air vent to the indoor unit.
Gas heat is a much better heating source where outside temperatures are commonly below 36 degrees.
Even electric furnaces perform better than heat pumps under these conditions.
Nov 30, 2014 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
My nokia 6303 get heat when charge and use
Problem with the Nokia 6303 Cell Phone My nokia 6303 get heat when charge and use
Mar 10, 2011 | Nokia 6303 Cell Phone
My upstairs heating is blowing cold air. The air handler in the attic is running but no heat. Down stairs is fine, I get heat
Question: Is your heat produced by a furnace? (If so-- what kind of fuel?)
Or is heat produced by Air Conditioning nits working in reverse-- called Heat Pumps?
If Heat Pumps, You realize that when it gets very cold outside, there is not much 'heat' out ther, to get the heat from outside temperature, right?
Sometimes the out-door coils will freeze up, and you get even less heat then--
Please tell us more-- so we can take the clues you give us, and we'll trouble shoot the problems as best we can remotely, like this-
Mack B
Jan 26, 2011 | American Standard Heating & Cooling
My central heat won't turn on. It's on automatic and won't turn on. When turned to On and Heat, it just blows cold air.
To get proper heat, keep your temp setting at 30+ degreeand also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.Check heating contactor is energized. If yes, and still no heat, check your heating element.
Jan 14, 2011 | Heating & Cooling
Window unit heater blows but dont get hot
To get proper heat, keep your temp setting at + 5 degreethan your room temp and also mode in "heat "position. If still no heat, check your heating sensorfor closed circuit by an OHMs metre.It it's with RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 13, 2011 | Kenwood Heating & Cooling
No heat in2002 saturn replacedthermostat but still no heat seems like antifreeze not cicculating
Verify whether the two tubes at firewall are getting hot, or one or the other is cold, or both are cold.
If the tubes don't get hot, then you won't get heat. If they are getting hot and you don't have heat, it's likely that the blend door actuator is not working properly to get heat from the heater core to the interior of the vehicle.
Jan 08, 2011 | 2001 Saturn SC
No heat thermostat was replaced can it be opened manually for heat to blow in and if so where is it located
all you could do is remove the thermostat to get heat in side it will just take longer to get heat
Oct 29, 2009 | 1998 Ford Taurus
Accessing the heating element
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
Feb 08, 2008 | Amana ALE643RB Electric Dryer
Kenmore 63942 Dryer Logo
874 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
