Question about Zebra Z4Mplus Label Printer
Z4m small labels
We are trying to print 4 lines but the last line is compressed, we have done a calibration and we are using Zebra labels. We have 7 machines and 2 of them are doing this. We have adjusted the top of label setting as high as we can.
    Champion:
  • Zebra Expert
  • 285 Answers
Try the pause test if print ok in some and have problems with other lables, is possible the belt.
Posted on May 05, 2008
6ya staff
SOURCE:
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
My zebra printer wont line up the labels and keeps saying paper out
run the sensor profile, check if check the gap, run manual calibration, if ask for reload media, please take 3 or 4 labels from the label rolar, put through the sensors (check if ribbon(if use) is install on the correct spots and don't stop the sensors to read the gaps) and run the manual calibration.
Sep 15, 2010 | Zebra Z4M Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
Zebra Z4m calibration doesn't work with different labels
You need to run the internal media sensor calibration setup that is built into the menu. This can take a few minutes but will solve this problem. The machine needs to be setup for the media you are running. This is no fun if you have to change a lot during a day and each media type has diferent qualities. It ususually happens when you are using labels from one manufacturer and then switch to a diferent brand. The backing material has diferent characteristics that the machine needs to be setup to be able to handle.
May 22, 2009 | Zebra Z4M Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Zebra Z4Mplus Label Printer Logo
101 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
