Question about Maytag Neptune MDE5500AY Electric Dryer
What is small blue plastic wheel?
While changing the belt on our maytag neptune dryer we noticed a small plastic blue wheel like thing in the bottom of our dryer. Its chewed up, possibly melted a little and difficult to tell exact shape. It looks like it could have possibly fallen off the drive motor? Any ideas on what it is and how much its needed? After replacing belt dryer seems to work fine.
    Problem Solver:
  • 9 Answers
The small blue wheel, just next to the Motor, is the tension pulley, your belt should go around it, before going around Drum
Posted on Jun 02, 2010
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
The small belt in the middle of the drum broke. After I pulled the drum off I noticed a small plastic wheel on a metal bracket loose in the bottom of the dryer. I can not see where this reataches and I...
its called an idler arm, it attaches next to the motor as this is what keeps tension on the belt so it will stay tight on the drum. If I remember correctly there is a slot on the bottom of the dryer close or right next/past the motor, slide it into that slot, with the small plastic wheel up next to/by the motor. I am attaching a diagram for the belt it will help. Good Luck and I hope I helped Tim:
http://www.applianceaid.com/images/belt-config.JPG
Remember the belt should ride in the middle of the drum and the back of the drum is lipped and should go behind the drum rollers. Once the belt is thread it will be tight and the idler arm will not longer be loose.
Mar 12, 2011 | Whirlpool LER4634J Electric Dryer
Loud banging noise in dryer (maytag). Have taken dryer apart. don't know how to tell if drum rollers, belt, and blower wheel are okay. Don't know what else could be causing loud noice.
the most common culprit of banging is an uneven spot on one of rollers. It may not be really noticable, but a slight flat spot can form on them.
Nov 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer -5 years old squeeks Now it wont start.
There are four small plastic guide wheels that surround the drum in order to keep it aligned. These will wear after a period of time. The wheels have no bearings, they just ride on a metal shaft. You may either try lubricating the rollers or replacing them. Thank you, Dana
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer MDG9700AWM fire comes on then shuts off after a few seconds. I have replaced the coils as well as the thermostat (part #20) if I just move the thermostat away from the burn tube...
TAKE THE FRONT OFF THE BLOWER WHEEL- THE METAL COVER ON THE BOTTOM LEFT CORNER- CHECK THE PLASTIC WHEEL INSIDE - THE CENTRES OF THE WHEEL WEAR OUT
ALSO CHECK THAT ANY EXHAUST DUCTING IS CLEAR
Jul 10, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The dryer will not tumble
do you hear any humming noise? does the heat come on?....no noise. most likely is a thermal fuse....small white fuse usually with two blue wires. humming means broken belt, bad motor or something stuck in blower wheel.
Jun 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer only heats in the timed setting not automatic setting
Thanks,
I fixed the dryer. I stopped at Thomas Appliance in Grand Blanc, MI and asked them if they knew which connection the wire went on. A service tech there said that usually there is only one choice and to look close. I did and he was right. I hooked the blue wire opposite of the ground and tested the dryer. It worked fine.
May 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag (#LDE9304ACE) sounds like a popcorn machine
has the blower wheel rounded out in the center motor shaft area .give that a check.it has fin's and about 10'' to 12'' in diamitter.other wise check rollers and glides.if dryer drum was oblong that would create a noise as it tumbled.you are welcome to email if needing more help. God bless ,tom
Jan 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
114 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
