Canon MX300 Office All-In-One Printer Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error 6000? - Canon MX300 Office All-In-One Printer
Lebanon Raingam
Level 3:
  • Canon Master 4,737 Answers
  • Posted on May 31, 2010
Lebanon Raingam
Canon Master
Level 3:
Answers
4737
Questions
Helped
1385150
Points
16345
1.It's needs to be reset. Press ON/OFF switch to reset the multifunction device with the power connected. 2. Clear any paper jam or any obstructions. 3. Clean the connectors and interfaces on the printer as well as on the cartridges. This will fix your problem. Good luck. Thanks for using FixYa.
  • Lebanon Raingam
    Lebanon Raingam May 31, 2010
    If it's on the network, please check the lan connection. In reality this issue has not been diagnosed by Cannon. I will try my best to update regarding this issue. Good luck.
2answers
My printer canon mx328 error 6000
Canon Printer Error Code 6000 is one of the typical errors that occur very frequently. It happens while users are attempting to print all of the printer's documents. The problem of Paper Jam is the main cause of this mistake.
Canon Printer Error Code 6000 refers to something in the printer that interferes with the movement of the carriage. In any case, I've been able to locate the problem: a piece of torn paper on the left side of the printer. Hard to get there However it's likely. The printer is running again! But often this is induced by a software error. Foreign objects, such as dust spores, pieces of paper, sticks, stickers, or other objects, block the proper opening of the paper feed tray. Due to the jam, the printer has an error of 6000.
Reasons for Canon printer error code 6000: The printer feed tray is wrongly fitted. A huge volume of documents next to the printer. The line feed is scratched or coated. Offer several print commands on paper at once. Faults in the sensor unit or in-line feed slit.
Our service: 24/7 support with the Printer expert team.
What does this error code mean 6000:0185578
Error code 6000 is usually a Fuser unit error. You need to replace the fuser Unit.
2answers
2helpful
2answers
Can u help me how to fix canon printing model is mp258 , error number is 6000, what is problem? thanks
Hi cinlytan,
With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
Hope it helps.
Thank you for using Fixya.
29helpful
2answers
what is remove for 6000 error simple tips
22helpful
5answers
3helpful
4answers
I have a Canon MP 520 Pixma printer and getting error code 6000
There is got to be a paper Jam inside the printer OR
Look for something that might have stuck up the roller ..
Thanks
Fame !
5helpful
CALL SERVICE 6000:0115785
Error 6000: is a fuser error 0115785 is your page count. You require a replacement fuser
24helpful
4answers
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
old marine
old marine
ZJ Limited
ZJ Limited
