Question about Dishwashers
I have a Maytag dishwasher MDBM601AWW. The control lock on the control pad will not unlock. I replaced the electronic control board and it worked for one wash. Control lock engaged again. I shut down the power and pressed the control lock for 3 seconds as directed by the owners manual. No luck. Please help Rich.
  • tracythillem Apr 01, 2009
    i have a maytag quiet series 200 i use the lock botton because my kids liek to cancl the load.. well i went to restart the dishwasher and no luck the lock wont shut off now.. i turned the main curcut breaker off over night and nothing!!!!! i held it in for more then 3 seconds could have even been 3 min. nothing!! maytag is sending soem one out on friday but if i can fix befor that would be great!! it is ********* considering i have only had the stupid thing since october!
    Genius:
  • 1,073 Answers
You have to power the unit back up and then holld the lock in for three seconds, if ths does not reset it then the console not the control bord needs to be replaced it comes with a new touch pad
Posted on Apr 10, 2008
SOURCE:
My maytag quiet series 300 lock light is on and wont work at all ,what do i do?/
there should be 2 buttons on the control pad, that when pressed simultaneously for 3 seconds will unlock the control.
Oct 24, 2011 | Maytag Dishwasher
The control panel is flashing a L. What does this mean?
Hi.
The model indicated: MDB5651A does not have display and the error codes are shown like flashing lights. If that is your model and problem please just tell me what lights are flashing.
In Maytag with display instead, the L on display means that the machine is control locked. That is not an error message, but a code telling that the machine has been locked by the user (probably by mistake since you are the user).
I quote from Maytag technical documentation:
? If a cycle or option pad is pressed after the controls have been locked, the indicator light next to lock graphic will flash five times. On selected models with a countdown display, the display will flash the symbol "L" simultaneously with lock indicator.
? This option does not lock the door, only the dishwasher controls.
To set :
1. Press the Heated Dry pad for three seconds.
2. An indicator light next to the lock graphic will illuminate when the controls are locked.
To Cancel Control Lock:
2. The indicator light will go off as instructed.
Try pressing the the Heated Dry pad for three seconds. If that doesn't work disconnect power. Connect back and try again unlock (power off does not remove the lock). If that still does not work there may be a faulty part. In that case turn appliance off and give me the full model number.
Start holding down the Heated Dry pad for three seconds. In normal conditions that is enough to get rid of the L and of control lock.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 20, 2011 | Maytag 24 in. MDBH950AWS Built-in...
The control lock light goes on as soon as I press the cycle to start the dishwasher. The dishwasher does not start, presumably because the control lock stays on. I do not know how to disable the control...
Hello & Welcome to FixYa
To unlock the controls press and hold the HEATED DRY button for 20seconds. If the problme returns then only option is touch pad replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Maytag Dishwasher
Maytag quietseries300 dishwasher in panel lock - can't unlock
depress the lock emblem on the touch pad and hold it down for 5-10 seconds. If the light lock does not go off then that means your LED touch pad is defective. Check in your owners manual for any warranty information on your touch pad. Most maytag offers 5 yr limited warranty on electronic parts which covers your touch pad.
thanks.
Dec 12, 2010 | Dishwashers
Can you send me directions on how to replace the control panel on my maytag dishwasher MDB5601AWW?
Take a screwdriver and remove the inner door panel. The control board has a cover over it with a 1/4" screw holding it in place. Get to the control board and put some eyes on it. Make sure the ribbon cable from the touchpanel is not damaged and well seated into the control board connector. If all looks good, use the techsheet MDBM601AWW to check the touchpanel continuity (tech sheet page 5, and you will need a multimeter to do this). If the panel tests ok you will need a control board 99003431
But it is more likely the touch panel 99003381
Remember to rate this answer, I hope helps. Good luck.
Oct 01, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Touch pad/control board not working?
PART NUMER 8193762 IS WHAT YOU WANT TO CHECK. YOU CAN SEE THE PICTURE OF THE PART AT REPAIRCLINIC.COM
Apr 24, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Mdb9100 totaly dead, does nothing, worked normally last load, circut breaker has been checked
Hi
Thanks for using FixYa. Please check for the following if your dishwasher is not working--
1. Fuse (blown or tripped).
2. 120 VAC supply wiring connection faulty. Repair or replace wire fasteners at dishwasher junction box.
3. Electronic control board faulty.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 04, 2009 | Maytag Dishwashers
Mdb9100 totaly dead, does nothing, workrd normally last load, cirtcut breaker has been checked
Hi
Thanks
Rylee
Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Jul 01, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
444 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
