Question about Brother IntelliFax-2820 Laser Fax
Back Cover Open Close The Back Cover Is Message I'm getting. What is the Problem?
    President:
  • 405 Answers
Open the front cover and remove the drum and toner(cartridge).
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Posted on Jun 02, 2010
3 Suggested Answers
  • 9 Answers
SOURCE: Pitney Bowes FD40 Folder Top Cover
did you fixed your problem with the folding machine??
Posted on Mar 18, 2010
  • 30 Answers
SOURCE: paper jam message but there is no paper jammed. opening and closing cover doesn't work.
hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
Posted on May 14, 2009
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
May 20, 2011 | Office Equipment & Supplies
Text on the display: back cover open,close the Back Cover we close the cover but no results
If you turn the printer off and then back on when there is a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Feb 25, 2011 | Brother MFC 7420 All-In-One Laser Printer
Printer will not print showing error 2200. How do l fix it?
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
I am getting an error message: 0xc18a0206
Hi
This is the proper procedure andif this fails, take it in for service.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer. Source(s): Computer Analyst / Microsoft Certified
Feb 12, 2010 | HP Photosmart D7160 InkJet Printer
Error 2200
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the top cover of the AIO.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Power off the AIO and remove the power supply from the back of the unit.
Close the top cover, reinsert the power supply, and power on the AIO.
Feb 06, 2010 | Lexmark P6350 All-In-One InkJet Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Not accepting new drum
remove and replace the drum unit, but leave the cover open. You should get the message "replace drum unit".....YES | NO? press "1" to reset. after it says "accepted", close cover.
Please rate me :)
Mar 29, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
680 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
