Question about Amana ARDS802SS Electric Kitchen Range
I have an Amana ARDS802SS Electric Kitchen Range the broiler works but bake does not??
    Genius:
  • 1,416 Answers
this means that there is disconnection on the element of the bake i.e heater (heat provider)
what it need is reconnection from the power supply.
And it could also be that the element is weak or bad which will need a replacement of a better one .
Good luck and thanks for using fixya.
Posted on May 31, 2010
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
My broiler and range work but my "bake" option will not produce any heat??? Please help!!!
If this is an electric range, it sounds like you have a bad bake element in the oven. The broiler and bake features each have their own heating element. Thats why the broiler still works. The following link explains how to replace a heating element in an electric range:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If the model range you have this question listed under is correct, the part number for a replacement element is WB44K5012. It lists for about $25 at pcappliancerepair.com.
If you have questions, or if the model number is not correct, please post back with your information so that I may be able to provide you with better assistance.. I hope you find this information helpful.
Oct 15, 2009 | Hotpoint RB757 Electric Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana electric oven won't get above 225 degrees. Takes over an hour to get to this temp.
sounds like only the broiler is working which comes on low during bake cycle. unplug or turn off breaker, remove bake element and check for continuity or take to someone who can.
Jun 13, 2009 | Amana AER5725QA Electric Kitchen Range
Kenmore range bake element doesn't work
check that the wiring is not bad and every thing is conected
Jun 04, 2009 | Kenmore 95922 / 95924 / 95929 Electric...
The oven and broiler won't heat
It sounds like an incomplete circuit so be careful.
Now all this is coming form my assumption that your using a setting that has both elements on at 1 time. like Baking.
First the most common thing:A COMMON TIE POINT;
A main wire burned off will cause both elements to not heat at the same time. It could be at the back going to one element then jump off and go to the second element. Or some times the manufacturer runs the wiring to the front on the controls, and a 3rd area that they could have a common tie point is right where the power comes into the oven. When this usually happens you'll have ok burners on top and no power completed to the bottom.
OR
It could be a switch that's bad and not allowing power to carry on to your oven controls at the thermostat.
If you need more help please get back to me and I'll post back. If this helped you figure it out or decide you need a tech please rate me as high as you can and thank you for using Fix Ya.
Apr 07, 2009 | Amana ARDS802SS Electric Kitchen Range
Amana agr5735qds oven will not light.  broiler works as do all the burners.
There are two igniters in your oven one for bake and one for broil. The bake igniter very likely needs to be replaced. Igniter part number is 70080764.
Dec 13, 2008 | Amana AGR5735QDS Gas Kitchen Range
Amana ARDS802SS Electric Kitchen Range Logo
147 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
