Question about SanDisk Sansa e260 MP3 Player
Sansa fuze will not reset believe on- off switch is inop.Plug into computer to recharge will stay on far a couple of minutes then shut itself off and won't turn back on.
  • 2,418 Answers
Heck out my tip posted here, hope this helps. ... Sansa Mp3 player frozen? How to reset and
Posted on May 31, 2010
My Sansa fuze is frozen! Help! It was connected to a laptop computer. I shut down the computer & THEN disconnected the fuze & now the fuze appears to be frozen....nothing at all happens when I push...
In order to solve this problem you have to push the 'off' switch toward the power button. Hold it for roughly about 10 seconds and it will automatically shut off. Hope this helps =)
Dec 28, 2010 | SanDisk Sansa Fuze MP3 Player
I recently purchased a Sansa Clip MP3. I downloaded audiobooks to it but they will not play. What do I need to do?
Not true!!! The Sansa Clip is actually the best mp3 player I have found for listing to audiobooks. Here is what you need to do. Download the latest firmware update on the Sandisk website. You must do this or it just won't work unless you are downloading books from Audible.
I use the Overdrive Media Console and download mp3 and WMA books from my state library. When you hit transfer, be sure it hit advanced options. Browse until you select the audiobook folder on your player. Then transfer to that.
The player will bookmark your last place on anything that is in your audiobook folder. You can easily switch back and forth between your music and book without losing your place! Love it!
It even has a sleep timer on it. I'm in heaven.
Apr 27, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Fuze 4gb wont turn on and isnt being recognized by my computer, iv also tried to soft reset it many times , nothing seems to work.. help plz..
I've had the same problem with my Sansa Fuze 2GB. It's pretty frustrating, but in order to get it to work, I let it sit without touching it or doing anything with it for a few days. For 2-5 days, do not turn on your Sansa Fuze. After the amount of time has passed, try the soft reset again.
Apr 22, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa fuze i plug it in to the computer and it doesn't recognize the device and i have tried all usb options on the device. What do i do it wont charge at all.????
When the Fuze can be switched on:
1. slide the power on switch shortly upwards to put the player on
2. hold the power on switch upwards for 15-20 seconds
3. release the power switch
Next try to switch the player on and see if it reacts normally.
Switch the player off again and try charging again, making connection to a computer.
When charging still doesn't start, disconnect the player from the computer:
4. slide the power switch downwards into the lock position,
forcing MSC mode
5. connect the player to the computer for charging in MSC mode
for a about 3 hours.
6. while charging use the Sansa Firmware Updater to check for
updates. When not installed already download the Sansa Updater
and run this execute file.
Updates for the player can only be performed in MSC mode.
The updater only works when you're logged in to the computer having administrator's rights and running Windows operating system.
MSC mode means that the computer sees the player as a removable disk. When in MSC mode, always disconnect through the icon "safely remove hardware" in the right corner below of the computer screen.
When the display of the player doesn't react at all after the reset and charging procedure, the battery of the player can:
a. be too far empty or
b. have a fast power loss.
The load of the power supply from the USB ports might be to weak to get the player charged.
When point a. is the case, an extra power adapter connected to a wall socket, providing more power, could help.
When the battery has had many loads it can be at its end of duty cycle. Then battery replacement will be required.
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa fuza 4gb shut off and it wont chare or come back on
Hi!
I had the same problem w/ my 4 GB Sansa Fuze after 3 wks. When I took it back to Future Shop I discovered a commis who showed me the secret way to debug it . You have to push & hold down the "Home" & the "Down/Submenu/Options" buttons simultanuously to reset it. It worked for me.
Sep 09, 2009 | SanDisk Sansa Fuze MP3 Player
Won't charge
PLease contact the maker at this website, you can pick your problem and product from a dropdown menu there and they are very helpful. www.sandisk.com
Mar 22, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk sansa fuze 2g mp3 player[black] is not charging for long
Try switching to MSC mode in the SETTINGS..USB menu on your player. Then plug it into your computer again. If you normally use a front USB connection on your computer, try one in the back. It's a more direct connection and works better for some people.
Some USB ports in the front are not strong enough. Your HP laptop should work.
I had the same issue.
Dec 05, 2008 | SanDisk Sansa Fuze MP3 Player
Frozen
Reset your Fuze by holding the power slider switch in the "On" position for 15-30 seconds. Release the button once the unit begins to power down.
Jul 02, 2008 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa e260 MP3 Player Logo
123 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
