My hm67 50 inch sond but not pic heard loud pop and lost pic
    President:
  • 1,099 Answers
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no HV, you either have a low voltage power supply problem, bad startup circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have HV as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HV), you probably have a startup problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for startup problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself). See the section: Bypassing the Startup Circuit for details.
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
Posted on Jun 02, 2010
Sony liquid crystal tv, was watching show then heard loud pop and tv went black but looks on. No pic or sound. has power but cant control tv at all. Complete silence and black screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 14, 2015 | Sony new bravia s-series 40-inch 1080p lcd...
I have 42 inch plazma no picture
Ur backlight video inverter board is dead.Buy parts like capacitors for replacement with soldering or buy the whole board.Tries these websites.Shopjimmy.com,Partstore.com or Ebay.com.
Sep 29, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Tv with no pic no sound on and off work
Hello mackenzie212, The loud pop you heard was most likely a capacitor exploding. I beleve the capacitor is also located in the power supply section of your TV. If you take the back off of the set you will see what can be described as a exploded, or bloated can. This component can be replaced, but I advise you to have it done by a qualified TV technician. This is due to the fact that their may be other unknown factors as to why the capacitor exploded, and a qualified TV technician can determine these causes past the obvious changing of the defective component. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | Hitachi 51F59 51" HDTV Projection...
I heard a loud pop then tv screen went black, now
hi friend,,,,,,,
i think due to high voltage resistor in dma board has blasted,,,,,
did u see any burnt marks,,,,,,,,,reply me
thank u,,,,,,,,
May 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sond cars
Go to Microsoft .com/downloads Reload drivers for the Vista OS
Feb 08, 2009 | HP (153147-001) Sound Card
Crackle and Pop
sonds like the power transistor. you will need to get it repaired by a someone qualified
Jul 27, 2008 | Protron PLTV-32 Television
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
