Question about Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP SUMP PUMP W/TETHERDFLOAT
Does an outdoor 1.5 h.p., 230 v shallow well pump need a GFCI breaker?
    Problem Solver:
  • 11 Answers
Anything within 6 feet of water needs a GFCI
Posted on May 31, 2010
No power in my 1998 coleman pop up sea pine camper
Two things you might check are the circuit breaker panel and the GFCI reset button. When I first got my pop up it was the GFCI and took me 2 days to figure it out.
Oct 09, 2014 | Sport & Outdoor - Others
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
Magnetek pool pump has 2 black and ground which one is the hot
Wiring diagram will show on side of pump, including voltage and amp rating.
120Volt and 240Volt circuits.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-a.jpg
If you are wiring for 240Volt, then both wires are hot.
If you are wiring for 120Volt, then connect Hot and Neutral to either black wire and check rotation of pump.
Make sure ground wire is connected to pump, and never touch electrified outdoor equipment when power is on, especially standing on outdoor surface. Stand on dry boards to avoid grounding yourself.
Oct 14, 2012 | Hayward 3/4hp Super Pump Inground Pool...
My pump has been running fine since may. Now after a few minutes it pops the breaker. I have tried another out let but it still does the same thing. It pumps out water very well. I checked the impeller and...
Could be a few things but here are a few, By "pops the breaker" are you refering to the breaker at the main panel in the house or the GFCI? Here is what a GFCI is asbestos_56_3.jpg If this is the thing that is poping then the problem is a ground fault. Eg. water is getting inside somewhere, or there is a nick in the cord. The GFCI should be on all outdoor outlets, this protects YOU from getting shocked, whereas the main breaker is to protect the wiring and the house from overloads. --Either way it is a dangerous situation--. I believe Little Giant has a good warranty policy. There are not really any repairable parts in these units. Don't get electrocuted, Contact the manufacturer. The fact that you say the oil is caramel colored (assuming you mean not clear but opaque) sounds like it has water in it.
Jun 14, 2011 | Little Giant 3E34N Dual Purpose Small...
Will the 7120z work on a gfi breaker
7120Z timer is electro-mechanical astronomic dawn-dusk timer so it should perform fine on gfci breaker.
http://waterheatertimer.org/Tork-timer-and-manuals.html#7200
The purpose of gfci is to identify electrical short at the moment it happens and trip off so nobody gets shocked.
Typically you find gfci with outdoor wiring, and astronomic timer controls outdoor lights.
If you locate box outdoors, it must have NENA3R raintight indoor/outdoor case.
If timer is indoors, then NENA1 enclosure/case is fine.
Apr 13, 2011 | TORK Hardware & Accessories
Can you tell me why everytime i turn the jets on in my hot tub it some times will run and other times it just trips the breaker
mmmmm....is the unit heating? sounds like maybe the heater is causing the GFCI to trip or could be the motor going bad.
Jan 25, 2011 | Flotec Corrosion Resistant Shallow Well...
I bought a new GE 20 amp GFCI circuit breaker and installed it to a new outdoor curcuit with two separate outlets. everything seems to work fine - polarities ok etc. connnected the white gfci line to the...
You can buy an inexpensive GFCI tester for as little as $10-$12. A better one with several mv settings will cost you a bit more. This way you can test this circuit and even GFCI receptacles. Then you'll know for sure if your breaker is working.
Nov 14, 2010 | General Electric 20 Amp, 1 Pole Thick Type...
HI there, Both my pool and spa motor won't work. I have a GFCI circuit breaker for my pool light and the circuit breaker is not operating - and needs to be replaced. I tried to reset it and won't reset. I...
If it is on the same circuit it is possible. It might not be resetting because there could be a problem on the circuit, possibly your pool motor or light. Anotherwards, your GFCI might be working properly if there is a problem on its circuit. I don't know how handy you are with electricity, but I would disconnect your main service and pull out the GFCI breaker and check for any shorts or problems on the circuit before I replace it. Good luck!
Mar 15, 2010 | AO Smith SQ1152 Pool Pump Motor
ELECTRIC FOR OUTSIDE BLOWER
Any time you are going to put an electrical circuit outdoors, you must by the electrical code, have that circuit ground fault protected. You can do this in one of two ways. The cheaper way is to place a GFCI outlet in the circuit between the power source and the outdoor blower. The pricey way is to change the circuit breaker for that circuit to a GFCI breaker. Doing that would make the entire circuit GFCI protected.
Please mark this answer as a fixya!
Mar 09, 2009 | Broan-NuTone N-335 Exterior Blower Range...
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP SUMP PUMP W/TETHERDFLOAT Logo
102 people viewed this question
Top Franklin Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Franklin Garden Expert? Answer questions, earn points and help others
