Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Getting hot front of the frig gets hot does anyone know
    President:
  • 949 Answers
This can be caused by the condenser running hot due to being dirty or the fan not running. See the link below for details on how to clean and check this.
Hot Rail between Freezer and Frig
Posted on May 31, 2010
Testimonial: "thanks"
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
Gasket between frig and freezer is darkening due to very hot surface on divider between sections
If it is that hot you really need to get this checked out ASAP. It could become a fire hazard.
Mar 12, 2014 | Admiral Refrigerators
The frig is not working but the freezer is going strong. Turned up the frig all the way but it does not seem to be doing anything. the tubes in the back of the frig are hot. I don't know anything about...
the tubes behind refrigerator are suppose to be hot.sounds like a defrost problem.turning up thethermostat will only make compressor run longer.cold air is made in freezer then gets moved over to the fridge side.your evaporator is more likely iced up.
Jun 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
REPLACING ICE TRAY ON LG FRIG
remove one screw on front left of ice maker, loosen two others-one in back and one on right, the ice maker will slide out. unhook wiring harness and the whole thing comes loose, couldn't figure out how to dismantle it but once I had it out of frig I let it warm up enough so the plastic would bend enuff to get it out.
Jan 09, 2009 | Refrigerators
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Hot point ice diamond has water in the fridge top section and its not very cold the green light is on the red off.what is the problem?do i need defrost it?
Jul 31, 2008 | Refrigerators
Freezer freezes OK, frig compartment doesnt get cold
Does the unit only have one compressor (black round object on back of unit). If yes then sounds as though you have lost some refrigerant (just enough to keep the freezer happy). If no (ie two compressors) check if both compressors hot. If both hot then have major problem if one cold then have a thermostat gone. Personally I think you have lost gas from your description, if so then you are looking at a dead fridge freezer. Hope this is of some help.
Mar 13, 2008 | Refrigerators
My frigerator
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Nov 12, 2007 | Frigidaire FRS3R5EMB Side by Side...
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
186 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
