Question about KitchenAid KEYS750LQ Electric Dryer
My dryer runs, but does not generate any heat. Is
My dryer runs, but does not generate any heat. Is this something I can fix myself?
  • KitchenAid Master
  • 43,501 Answers
Hi, If you have a gas dryerMy dryer runs, but does not generate any heat.  Is - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
My dryer runs, but does not generate any heat. Is - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingMy dryer runs, but does not generate any heat.  Is - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 08, 2010
Hi, My ED56 dryer has just stopped heating.
The heating element likely has failed.
Jun 27, 2016 | Dryers
My kenmore 5200 series gas dryer won't heat. My
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Kenmore Dryers
Kenmore Dryer will heat up, but drum will not turn
the belt is off or broken . pull it down and take a look.
Aug 04, 2009 | Dryers
My bottome dryer wont heat up but the top dryer heats
I have the same problem and called a repair center to fix. They came out last Thursday and and ordered the parts (thermite and thermo fuse). Waiting for a call that they received and ready to repair.
Aug 01, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Gas dryer runs but does not generate heat
See if there is something blocking the vent. This will cause it not to heat. Are you sure the gas orifices are clean and moreover, is the gas pilot on.
Jan 17, 2009 | Whirlpool Dryers
Dryer will not heat and timer doesn't budge when running
First of all if this is a gas dryer you should have a tecnician fix so you have no gas problems. If not it sound like you definitekly need a new timer, that is why it does not heat up. All of your cintrols run through the time. It lets the machine know when to go on or off and get hotter or cooler depending on what type of cycle you chose. I hope this helps.
Jan 08, 2009 | Dryers
Dryer shuts off when releasing start button. Will run while pressing down start button, but no heat is generated. Sears repair man wanted to replace Even Heat Control Board for $350. I bought the part...
replace the motor, as you are holding in the start button you are making the dryer run in the start winding of the motor, it is designed to only stay in this winding untill the centrifigual switch on the motor automaticaily switches it to the run winding, when the motor switch knows that it is using the run winding it closes the motor switch contact for the heater to come on, replace the motor
Apr 12, 2008 | Kenmore 63942 Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER not heating
Check the terminal block and make sure you're getting 220. If you only get 110, the dryer will run but without heat.
Apr 03, 2008 | Maytag PYE2300AY Electric Dryer
KitchenAid KEYS750LQ Electric Dryer Logo
137 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
