Question about Sony VAIO VGN-N110G/W Notebook
How disassemble to change hard drive - Sony VAIO VGN-N110G/W Notebook
  • 4,737 Answers
Please check out this video, http://www.youtube.com/watch?v=4CFrDub28ms Thanks for using fixya. good luck.
Posted on May 31, 2010
I want to change the harddisk, but I can not get the computer opened in order to so. Any suggestions?
In order to change the hard drive on this laptop you are going to have the remove the battery and the keyboard because the hard drive is directly under the keys. When you remove the battery you will see 3 screws, remove them. Open the screen and flip the laptop over to see, in the battery compartment, the keyboard release access. Insert a flexible tool and press inward to release the keyboard. Flip the laptop over and gently lift up the top part of the keyboard until it releases. You will see you have the hard drive there. Unscrew it, remove the bracket and replace the hard drive. Be careful not to loose any screws and never force a screw back into place.
Jul 06, 2011 | Compaq Mini 110c-1001NR Notebook
My ac adapter suddenly started smoking but i was able to turn it off immediately. will it affect ny hard drive? is it a problem with the hard drive or adapter?
Surely there is a short-circuit problem with your adapter.The adapter is propably off .You cant know for sure if hdd was affected.Dont connect the adapter to the case anymore for now.
Most external hard disks can be disassembled with relative ease.Disassemble it and check at a local store to find a case for external hdd (relatively low price) so you can see if the hdd works properly or not.
Apr 07, 2011 | Acomdata (HD060U2FE-72) 60 GB Hard Drive
How can I install internal Toshiba MK3265GSX into my notebook with Windows XP (SP3)? Setup software can't find hard disk. Where can I find driver for this device for XP?
Hi
Disassemble the laptop, follow the bellow link for details,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-1200/take-apart-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Tecra-A2/notebook-disassembly-guide.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L355D/laptop-disassembly-1.htm
For install xp follow another link,
xp setup not detect hdd http://www.microsoft.com/downloads/en/confirmation.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/ http://www.nliteos.com/download.html http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/ Hope this helps,reply me for further instruction,
Feb 27, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
How do i fix an I/O Device Error on External Hard Drive?? or is it need to be taken in?
You can disassemble the drive and connect it internally to a desktop computer. The hard drives inside of these external enclosures are identical to ones found in desktops or laptops. The drive should show up as another hard drive on your machine where you can get all of the data back.
The circuit board inside these drives that handles the data transfer through USB can get worn out and sometimes do go bad.
Disassembling the drive will destroy the enclosure usually.
Jan 25, 2011 | Western Digital 250GB MyBook External USB...
My laptop no longer recognizes my external hard drive. Device Manager gives me an error code 10.
Connect the Maxtor to a different computer, to see if the device works in some other computer.
If the warranty is still valid, exercise the warranty to get a replacement.
If the warranty has expired, disassemble the casing, and disconnect the USB-to-disk-drive interface from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some other computer, to see if the USB-to-disk-drive interface is the part that failed.
If all else fails, search online for commercial "data recovery services" -- for a large amount of money, they will disassemble the disk-drive, repair it, just long-enough to copy your files.
Aug 09, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My lacie hard drive is not recognized by my laptop when I plug it in and turn it on. What is my next step?
Change the cable between the computer and the external drive.
Disassemble the external casing, and connect the "internal" hard-drive as a "slave" hard-drive in a desktop computer, to see if the hard-drive is OK.
Exercise the warranty, to get a replacement.
Apr 03, 2010 | Computers & Internet
LaCie Hard Drive Dropped
Disassembling a HDD is not for the faint of heart or anyone without a "cleanroom laboratory' and a whole lot of skill. If it dropped and it now chatters or clicks, or worse - grinds, it is likely beyond repair. Contact the manufacturer - they're your best bet.
May 07, 2008 | LaCie (300728U) 250 GB Hard Drive
Change hard drive
You will have to disassemble the laptop a bit to swap hard drives. Check this link: http://www.flickr.com/photos/dnhoshor/sets/72157602004333279/show/
it shows a photo disassembly that was made to repair the power jack bu you will see the hard drive in image # 10
hope this helps
Apr 23, 2008 | Averatec 3200 Notebook
Replacing hard drive
Hello frank you can get info of how to change your apple g3ibook on various website like www.eserviceinfo.com and many other by searching on google and by typing the ibookseries followed by free manual or visite www.apple.com for more info
Jan 15, 2007 | Apple 12" iBook G3 700Mhz with 256 RAM,...
Sony VAIO VGN-N110G/W Notebook Logo
91 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
