Question about Canon Office Equipment & Supplies
Print head holder does not move to the middle when you open cover
    President:
  • 3,278 Answers
Hello.
Carefully remove the top covers to reveal the print head following the arrows on the covers (you may need a flathead screw driver to carefully unfasten the covers.
There is a device that slides back and forth that serves as a squeegie for the printhead. When you turn the printer on and off it should move. If it tries to move but does not, then this is most likely the cause of the error and is either stuck due to debris such as a piece of paper or more likely gummed up with old ink. If you then nudge the mechanism gently while turning on the printer, it should start to move. You will then need to clean it so that the mechanism does not get stuck again.
If this suggestion does not work, please provide the model number of your printer.
Hope this helps.
Posted on May 31, 2010
  • 1 more comment
  • tao_wang1715 May 31, 2010
    Hi NinaE,
    I can move the print head holder by my hand. My printer model is Canon PIXMA MP780. It is showing "check printer press OK". I did,but printer still keep showing samething. I can not find place to unfast cover
  • NinaE May 31, 2010
    Hello, again.
    Give this a try:
    Try resetting the printer:
    1- On the operator panel, press and hold the
    On/Off button for 10 seconds. (The display will go blank.)
    2- Unplug the
    power cord. Wait 30 seconds and plug it again.
    3- Press the On/Off button
    again.
    4- Wait until the device has completed its cycling process before
    submitting another job request.
    If this does not resolve your problem, you probably have a hardware issue.
  • tao_wang1715 Jun 01, 2010
    Thank you. I tried, but it does not work. The print head houlder does not move at all except moving by hand. What should I do next.
HOW CAN I REMOVE THE PRINT HEAD ASSEMBLY ON A CANON MX340?
Follow the given steps:
1. Confirm that the printer is powered on.
2. Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 12, 2012 | Canon PIXMA MP130 All-In-One InkJet...
I need to extract the printhead from a Canon MP540 printer in order to install a new one. I have just received an incomplete answer from FIXYA. When I turn on the printer and raise the cover, the...
The print head is not designed to be moved manually and damage may occur if you try to do so forcefully.
To center the print head to replace ink tanks and to replace/remove print head you should do the following:
1. Make sure power is turned on and open the Paper Output Tray gently. 2. Lift the scanning unit (cover) until it stops. Lift with document cover closed. The print head holder should move to the replacement position (center).
Do not force print head holder to move nor touch it while it's moving. These parts are very delicate and generally are made mostly of plastic.
IMPORTANT If the Scanning Unit (Cover) is left open for more than 10 minutes, the Print Head Holder moves to the right. In this case, close and reopen the Scanning Unit (Cover).
May 04, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Error 5200
If the printer is turned on, turn it off then unplug from the outlet
Open the cover and move the ink cartridge holder to the middle part
Lift the gray lever then remove the print head along with the cartridges
Bring down the gray lever then close the cover
Plug the printer again and stand by until it warms up
Put the cartridges back to their position
Put back the print head then close the cover
Hopefully, it will work now.
Apr 19, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
How do I find and remove the printhead?
Here you go:
8. Close the inner cover and top cover. __________________
"If it's really a supercomputer, how come the bullets don't bounce off when I shoot it ?"
Jul 09, 2010 | Canon Office Equipment & Supplies
Where is the serial number on a Canon Pixma MX870?
The serial number is located on the guide for the print head holder. Open the cover, as if your going to change the ink. To the right of the print head holder (where the ink goes), on the guide that moves the holder back and forth, there is a white label with the serial number. The number starts with four letters and ends with five numbers.
Mar 28, 2010 | Canon Office Equipment & Supplies
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
I cannot remove the printhead to install a new one , afrain of breaking somethin
1.Confirm that the printer is powered on.
Nov 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
32 people viewed this question
old marine
old marine
